      09-29-2022, 10:55 AM   #1
MorenoX3
Drives: 06 bmw 325i , 2011 bmw 535i
Help with code p0341
Hi everyone,
I'm new to this forums and I will appreciate if someone has a tip on how to fix this problem.
I replaced the valve cover gasket on my daughters 06 325i and after I finish the car run good for 10-15 minutes and then started shaking and I got this code,
I replaced the camshaft position sensors and it runs smoothly for another 10-15 minutes and then started shaking and the same code comes up.
Before the gasket replacement the car was running very good.
This is the third time I replaced the gasket and I never got any issues on the previous jobs.
If anyone had this problem before and has an update I appreciate any help,
Thank you.
      09-30-2022, 12:02 PM   #2
chassis
chassis's Avatar
6553
Drives: 9Y0 Cayenne S
Google says cam sensor circuit is amiss.
Recheck your work.
Something is loose or broken. Replace the battery if more than 4 years old. Likely an easy fix.
      09-30-2022, 12:56 PM   #3
dangerus_car
Drives: F30
Originally Posted by MorenoX3 View Post
Hi everyone,
Thank you.
Why do you post an 06 bmw on a 11 forum? You should post it on a relevant forum to get better response
