Steve Thomas BMW
      06-08-2014, 06:00 AM   #1
Cinder
Drives: M3 e92
dct Paddels on omp corsa
hi guys, im building up my e92 for the nordschleife here in germany.
now I removed the complete Airbag-stuff and want to replace the oem steering wheel with the dished omp corsa superleggera.
before I build adapters for the dct paddles my question:
does anybody know if there is a solution to buy to mount or replace the oem paddles?
CindeR
      06-08-2014, 10:52 AM   #2
Kunman
Drives: m3
would like to know as well.
One solution would be to forgo the paddles and shift via a modified longer dct shift knob.
      06-09-2014, 03:20 AM   #3
PAKMAN
PAKMAN's Avatar
North Korea
277
Drives: 2011 E92 M3
2011 BMW E92 M3  [4.75]
2006 e90 330i  [2.75]
I am actually working on building adapters for a nardi deep corn wheel. I will update when done
stock car
      06-10-2014, 05:29 PM   #4
Cinder
Drives: M3 e92
I tried this last summer, but the feeling was not good - the stick is too long, so its too easy to shift and the way is too long.
its better to bring the whole unit upwards- maybe without the emergency shift because the cable is too short.
but i will get tomorrow the new steering wheel and try to produce adapters as well - i still can't find a solution to buy.
      06-10-2014, 06:24 PM   #5
Genro757
///M-Flight VP
Genro757's Avatar
Drives: '13 Frozen Red Edition E92 M3
2013 E92 M3  [0.00]
OP have you checked out the paddles offered by bmwpedals.com or EAS? I've got a set of paddles from bmwpedals.com that I swapped out from the OEM ones...these paddles are just as long as the ones you will find on the M6 and are fairly easy to install.
2013 "Frozen Red Edition" E92 M3, M-DCT with all the 'fixin's, Akrapovic Evolution w/CF Tips, BPM Stage 2 Tune, BPM DCT Software
      06-19-2014, 01:47 PM   #6
Cinder
Drives: M3 e92
Hi, thanks for your reply, the Problem is, i want to mount the paddles not on the stock steering wheel. I have this one:
http://cdn1.bigcommerce.com/server28...65632_zoom.jpg
So, I started to make an adapter for the paddles, and now I saw this one:
http://www.tunersgroup.com/Products/...ddleshift.html
The shifter should fit the E9x. I just asked them a few questions (about the wiring, if the angle is adjustable etc.)
Does anybody tried them out?
br cinder
      06-19-2014, 08:48 PM   #7
Kunman
Drives: m3
you should give IND a call, i think they were working on a solution to this problem.
      06-23-2014, 03:04 PM   #8
Cinder
Drives: M3 e92
Ok, I will buy these ones:
they are easy to fit the OEM harness, fit OMP wheel (nardi as well ), work on dished steering wheels and have fast support.
br
CindeR
      06-23-2014, 03:22 PM   #9
warp10
warp10's Avatar
336
2011 M3  [5.00]
2011 28i X3  [0.00]
please post details once installed
      06-23-2014, 04:59 PM   #10
The HACK
Roger Murdock
The HACK's Avatar
906
Drives: 2006 MZ4C, 2015 Fiat 500e
As long as part number 3 in diagram is retained on the original steering column, you can mount the factory paddles to anything and make it work.
http://www.realoem.com/bmw/showparts...88&hg=61&fg=35
The hell I don't! LISTEN, KID! I've been hearing that crap ever since I was at UCLA. I'm out there busting my buns every night! Tell your old man to drag Walton and Lanier up and down the court for 48 minutes!
-Roger Murdock
Search this Thread:
Advanced Search
