European Auto Source
      06-29-2014, 06:17 AM   #1
SDPRT
SDPRT's Avatar
Drives: 08 M3 Space Gray/MT
2008 BMW M3 e92  [0.00]
Running 265/35/18 tires on Apex Arc8 18x10et25??
I have new set of Hankook 265/35/18 RS3 that I was going to run on a 18x9.5 wheel for the occasional track/mostly daily but now I want a set of Apex Arc8 18x10 et 25. I know it will fit but will it be safe for the track (Willow Springs). I know most run 275 but seeing if 265 could work so I can burn through this set before I order new rubber.
RPI GTc/ RPI X-Pipe/DINAN Stage2/KWV3/18" BC Forged RS41/Mode Carbon V2 GTS/RPI AF + Red Scoops/Lux Angel Eyes.
      06-29-2014, 08:39 AM   #2
arter
collecting toys
arter's Avatar
31
Drives: M3 MCB
mfg recommendation rim size for 265/35/18 is 9.0 to 10.5 inches, so your 10 inches rims should be okay
2011 e92 M3 Monte Carlo Blue ESS 535 - gone but not forgotten
2015 cayman GTS - new toy
2006 SLK 55 AMG sold
      06-29-2014, 08:40 AM   #3
E92inSG
E92inSG's Avatar
20
U will be fine running those on the track
      06-29-2014, 06:13 PM   #4
SDPRT
SDPRT's Avatar
Great, thanks guys.
      06-29-2014, 08:00 PM   #5
slicer
slicer's Avatar
Drives: '13 E92 M3
You should expect to need spacers in the front.
'13 E92 M3 - Alpine Wht - Ohlins TTX, Fall-Line / SPL Suspension Arms, Eibach Sways, MRF Solid SF Bush, AP Racing Brakes (Essex), Cobra Seats w/BK Mount, Akrapovic GT4, CSF Cooling, VPhreaks Battery, OE M3 GTS - Lip and Interior, M235ir Wing, Varis Diffuser, BBS E88
'17 F31 M-Sport - 513M Wheels, H&R Springs
'Instagram - @slicer_m
      06-30-2014, 12:08 PM   #6
LiM3y
LiM3y's Avatar
United Kingdom
41
Drives: 2008 E90 M3
why spacers?
      06-30-2014, 12:16 PM   #7
kevin///mlee
kevin///mlee's Avatar
88
Drives: E90 M3, E30 M3
Originally Posted by LiM3y View Post
why spacers?
18x10" ET25 rims have a known issue with KW coilovers (V3 and clubsports) and inner barrel clearance. I believe a 5mm spacer should be sufficient for clearance with this setup.
Akrapovic | AngeliBright | APEX | Hankook | IND | JRZ RS1 | Macht Schnell | Mode Carbon | Vorsteiner
      06-30-2014, 01:20 PM   #8
LiM3y
LiM3y's Avatar
United Kingdom
41
Drives: 2008 E90 M3
Okay - thanks! Do TC Kline's have this issue too? I am just about to pull the trigger on these (They are selling at a ~$950 discount right now)
      07-01-2014, 02:14 PM   #9
Expert@ApexRaceParts
Expert@ApexRaceParts's Avatar
442
Drives: M3
That is correct, a 5mm spacer would be needed for wheel clearance from the progressive V-shaped springs of the KW V3's, and the lower spring perch of the KW Clubsports due to the helper spring. The 18x10" ET25 can surely be used with a 265/35/18, though the preferred tire fitment for the e9x M3 is 275/35/18 to gain more traction and utilizing the 10" width a bit better.
TC Klines should be utilizing a linear race spring on their coilover system, so there should not be any issues with the 18x10" ET25 fitment.
      07-01-2014, 03:26 PM   #10
LiM3y
LiM3y's Avatar
United Kingdom
41
Drives: 2008 E90 M3
Search this Thread:
Advanced Search
