02-01-2016, 05:56 PM | #1 |
Rep 90
2013 E93 Keyhole Delete
So I bought used from a member on here. I installed it and it looked fine but the car locking system kept cycling. Any ideas why? Do I need to have it coded out?
I heard one can swap these covers (remove the OEM cover with hole and replace with one that has no hole) but only some aftermarket manufacturers of these covers will fit. Of course I get the one that doesn't. And by the way, yes, I am aware if the battery goes dead I will have a major problem getting into the car if locked. Thanks for your time. |
02-02-2016, 04:13 PM | #2 |
Rep 63
Drives: 2013 E93 M3 LMB, 6MT
I recently installed one from IND on my '13 E93. I put the locking mechanism back in underneath rather than the plastic "blank" that was shipped with it (not sure if that would have any impact). It was a tight fit, and required some coaxing but no issues...
No coding should be required for this. |
02-16-2016, 10:51 AM | #3 | |
Speed Demon
205
Rep 3,690
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i |
02-17-2016, 03:59 PM | #4 |
Rep 90
OK. Well, I am not sure of the manufacturer of the cover but it does not allow for re-installing the lock cylinder (I tried and the ears that holds the cover on to the cylinder does not fit onto their catch-point). So I am trying this without installing the lock cylinder. Door locks kept acting like they are trying to unlock even though they were already unlocked. Soooo...I just went back to stock. No big deal but perplexing just the same...
Thanks |
