09-05-2010, 12:58 PM | #1 |
Rep 6,759
Help: Crossover has 4 inputs, amp output only 2 wires!
I think I know how to connect it, but don't want to blow something up.
I'm installing a set of Rainbow speakers in the front doors of my sedan, and the crossovers have 4 inputs (labeled + tweeter, - tweeter, + woofer, - woofer) - but there are only 2 wires coming out of the door. Using (for now) the stock HiFi amp. My instinct is to connect the 2 wires from the door in parallel, giving the woofer and tweeter each the same signal. Does this make sense, or am I making a big mistake? Any ideas are much appreciated...
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
09-05-2010, 01:08 PM | #2 | |
Rep 2,339
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
09-05-2010, 01:27 PM | #3 | |
Rep 6,759
Edit: And the Rainbow website is less than worthless.
09-05-2010, 01:45 PM | #4 |
Rep 2,339
What model components do you have? I just looked up the Rainbow line and even some of the higher end sets don't have bi-amp capability through the passive crossover? Do you have a picture of the crossover?
09-05-2010, 01:55 PM | #5 | |
Rep 6,759
BTW the crossovers are massive, but that's a different story altogether.
09-05-2010, 02:06 PM | #6 |
Rep 2,339
See the four black tabs on the left side of the crossover. Those look like some kind of jumper for setting various things. Each one probably has a different function which could include input selection, output attenuation, and even sound shaping. If you can't find the manual, I suggest you contact VP Electricity via PM since he's a Rainbow dealer and he might be able to give you more insight on exactly how to set those up.
09-05-2010, 04:10 PM | #7 | |
Rep 6,759
I got the speakers from VP Electricity and he is trying to obtain a copy of the manual from Rainbow (which may take a little while). But in the meantime, I'm trying to find some more info...
09-05-2010, 04:46 PM | #8 | |
Rep 2,339
09-05-2010, 05:17 PM | #9 |
Rep 3,201
Those need jumper wires across the inputs. PITA but it does allow biamping. I love those xovers but hate the housing and packaging.
Will call in a couple. ________ Kawasaki ZL1000A Last edited by VP Electricity; 01-19-2011 at 04:26 AM.. |
09-05-2010, 06:00 PM | #10 |
Rep 12,996
09-05-2010, 06:31 PM | #11 | ||
Rep 6,759
I received instructions regarding the internal jumpers too - I think S2 is a tweeter attenuator, S3 the filter slope and S4/S5 tweeter polarity. I may have gotten the S2 and S3 names confused. In any case I'll receive a manual shortly and will double-check this. I also found a great spot for the huge crossovers, I'll post pics tomorrow. Impressions also tomorrow. Guys, I appreciate your help and willingness to work with me - should you find yourselves in the DC area, the beer is on me.
09-05-2010, 06:31 PM | #12 |
Rep 3,201
All handled. Had to comed into the shop and pull the hard coy - no online manual (!).
There are 4" LP filter curve, tweeter HP filter and attenuation, and tweeter polarity jumper settings. He's bringing the tweeter output down two clicks, engaging the notch filter in the HP output, using the lower level output of the LP curve (since the 4" is so high in the door), and maintaining the same polarity. ________ Ducati Apollo Last edited by VP Electricity; 01-19-2011 at 04:26 AM.. |
09-05-2010, 07:25 PM | #13 |
Rep 3,201
S1 (inside the inductor) changes the mid LP point and alignment a bit.
S2 is a notch filter on the tweeter. Engage it in our cars. If it's off axis, leave the notch filter on. S3 is tweeter attenuation. 5 levels available. S4 and 5 change the tweeter polarity relative to the mid. ________ iolite portable vaporizer Last edited by VP Electricity; 01-19-2011 at 04:26 AM.. |
09-05-2010, 07:31 PM | #14 |
Rep 2,339
Wow. Pretty nice set of adjustments on such a moderately priced speaker set.
09-05-2010, 11:45 PM | #16 |
Rep 6,759
Not to mention, the crossover is heavier than the OEM speaker...
09-13-2010, 02:43 PM | #17 |
Rep 158
Are these going to be mounted in the doors? I'm looking to get a set for my e92, but I was expecting something a lot smaller for the crossover.
09-13-2010, 05:17 PM | #18 | |
Rep 6,759
I might be able to install the amp & subs this weekend, after which I'll post a full report.
09-14-2010, 02:45 PM | #19 |
Rep 4,145
That pocket in the door almost looks like it was made for the x-over. Please do give us your impressions of the speakers when done. Thanks.
Cheers. P.S. It's pretty cool how you duct taped the components to the door panel
2017 F80 YMB.
09-14-2010, 03:54 PM | #20 | |
Rep 6,759
The dynamat is much stronger, thicker and stickier than duct tape, I'd recommend it to anyone. (Plus needless to say, helps with sound insulation). If you are referring to the speaker, that's not the main support for it - I used VP Electricity's metal rings to secure the speaker to the door panel. The dynamat is added on to complete the sound insulation, that's all.
09-14-2010, 04:12 PM | #21 |
Rep 4,145
It was joke really. That's what the LOL smiley was there for. It's pretty clear that you used dynamat. It just looks like duct tape in the pics. I don't think I'd ever seriously use duct tape or dynamat to mount a speaker. But in case of emergency ...
Cheers.
2017 F80 YMB.
09-14-2010, 04:27 PM | #22 |
Rep 6,759
Wasn't sure... Anyway, cheers.
