BPM
      06-02-2020, 10:52 AM   #1
Captain Starbucks
Drives: 2011 M3 6MT
Floaty fix while retaining EDC?
Hi,
I bought my car last year lowered on H&R. It's my daily and there are plenty of crap roads where I live. I raised it back up with some factory ZCP springs and my original EDC Non-ZCP dampers with 63k on them.
Now, the ride is good and I think the car actually handles better based on entry and exit speeds on the same corners I routinely hit on my daily commute. My problem is that the scalpel steering and feeling is gone. I miss it. Not bad enough go back to bouncing around and dragging guts all the time but I do miss it.
I've heard others complain about the floatiness as well.
I did not get it aligned after raising back up. Tracks straight, wheel is centered but that doesn't really mean a whole lot.
Ideas?
Thank you.
Rob in Tacoma
2011 M3 6MT
Alpine white, ZCP springs, AFE intake, Black ZCP wheels, Borla ATAK. BE bearings/ARP bolts 02MAR2020@ 60k.
2001 Ford F250 crew cab long box 4wd Diesel 6MT
1968 Impala Convertible, original owners
      06-02-2020, 11:11 AM   #2
wyatth
Drives: E90 ZCP
If you like the EDC ride but just want it tightened up front with some better turn in, I highly recommend the Dinan front sway bar and camber plates with a proper alignment. I wanted to retain my (ZCP) EDC suspension as well and these components really perfected it IMO.
Cheers,
Wyatt from Tacoma
//steve\\1074.00
      06-02-2020, 02:30 PM   #3
Captain Starbucks
Drives: 2011 M3 6MT
Thanks for the info Wyatt.
My issue isn't so much with turn in and cornering. I should have been a bit more clear.
Cruising down the freeway, the car seems....not nervous per se, that would be an overstatement. Just not nearly as planted and confident in a straight line at freeway speed. I want that back.
2011 M3 6MT
      06-02-2020, 07:40 PM   #4
Redd
Rear subframe bushings and front monoballs.
      06-08-2020, 05:00 PM   #5
Z K
Z K's Avatar
1889
Drives: E90 M3, G20 M340i
The floatiness is a combination of lack of rebound from the OEM EDC shocks and the car riding on the bump stops under hard cornering.
EDC adjustment does not change the rebound of the shock - it only changes the bound to make it feel stiff on compression. That's what gives it the "float" sensation as the shock is not rebounding fast enough between bumps.
Short of replacing the oem shocks with higher rebound shorter body shocks with shorter bump stops i.e. some aftermarket coilovers, I don't think there is solution.
A partial solution may be to replace the OEM EDC shocks with aftermarket shocks that are valved for more sporty handling and add shorter bump stops. This assumes you are using OEM springs.
Auto Detailing Enthusiast!
      06-08-2020, 05:19 PM   #6
Captain Starbucks
Drives: 2011 M3 6MT
I'm sure the floaty feeling is there in the corners but I don't notice it. I do notice in corners the oscillating pitch that Isaac talks about.
Regarding the rebound, yeah, the car should make adjustments to the rebound when you change the EDC settings but that doesn't happen.
My EDC is working, and I like it. I change settings on it at least 4x per commute. 4x in the morning, 4x in the evening. I like the adjustability. There are some pretty crappy roads in town, but then some 80 mph sweepers outside of town.
Overall, I'm very happy with the way the car handles, just was a bit disappointed with the steering after I raised it back up on ZCP springs after getting rid of the horrible H&R ride.
2011 M3 6MT
