06-07-2015, 08:00 PM | #1 |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
459
Rep 2,002
Drives: 2011 E92 M3 DCT/ESS 625 kit
Is there a different between 96y and 100y
Recently replaced my tires from stock oem sizes to 255/275 pss and noticed the front tire 96y and rear 100y. Not sure what this means.
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
06-07-2015, 08:32 PM | #2 |
Rep 166
Basically 96 and 100 is just max weight load a car can handle. 96 mean 1565lbs max and 100 mean 1764lbs max. The "Y" is speed index, higher the letter the faster the speed rating which in your case Y is up to 186 mph the tire can handle.
http://www.tirerack.com/tires/tirete....jsp?techid=35 I hope the above link will clear your confusion. |
06-07-2015, 08:33 PM | #3 | |
459
Rep 2,002
06-08-2015, 08:24 AM | #5 |
Rep 1,479
Drives: 2017 F80 M3
Absolutely incorrect. It's due to the design specifications/requirements. Michelin has multiple designs for the same model tire and size because one design doesn't fit all cars (e.g., model, make, and size).
_______________________
1991 E30 M3/Brilliantrot 2017 F80 M3/AW |
06-08-2015, 08:32 AM | #6 | |
459
Rep 2,002
06-08-2015, 09:36 AM | #7 | |
M3Post Supporting Vendor
87
Rep 964
While MadeInTaiwan is essentially correct, bdaddylo does raise a worthwhile point. It is true that (all else being equal) a larger tire will generally be able to handle more weight. It is also true that there are often different load ratings available in a given size. They make both 92 and 96 load index PSS in 255/35R19, and both 96 and 100 load index for the rear.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions. |
06-08-2015, 09:58 AM | #8 |
459
Rep 2,002
Ok thanks for your help.
06-08-2015, 03:42 PM | #9 | |
Rep 1,479
Drives: 2017 F80 M3
