05-28-2015, 04:39 PM | #1 |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
459
Rep 2,002
Drives: 2011 E92 M3 DCT/ESS 625 kit
pls help with offsets on Work VSXX 20 inch wheels
Not familiar with offsets especially when going with after market wheels. My local wheel shop has the following wheels work vsxx in stock which is better then waiting a few months. I don't want a stretched tire look and the lip over exceeding the tire wall IMO it looks a little to ghetto for my taste. Hopefully you guys can help me out before I take the plunge. I also want to go with Michelin pss car is lowered on swift springs. Hopefully you can also recommend a tire size. Thanks guys!
20x9.5 +24 20x11 +25 Full reserve lip 20x9.5 +28 20x10.5 +29 Step lip (This setup is less aggressive) Last edited by Installsplus; 05-28-2015 at 04:48 PM.. |
05-31-2015, 10:54 AM | #3 |
Rep 3,482
I would roll on the second set up with the stepped lip and then do 275/295 tires. More specifically, run 275/30/20 front and 295/30/20 rear. You shouldn't rub.
BMWCCA:518970 |
05-31-2015, 12:20 PM | #4 | |
459
Rep 2,002
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
05-31-2015, 02:02 PM | #5 |
Rep 1,017
Drives: 2010 E92 M3 6MT
255/30 on a 20 inch wheel is as wide as iv seen with no rub, its a pretty freaking tall tire. Rear you can go up to 315 depending on offset. One of my sets are 20's
20x11 ET33 315/25/20 20x9 ET 17 255/30/20 Much prefer my 18inch volks though.
05-31-2015, 05:14 PM | #6 |
Rep 3,482
275 might be too wide now that I think about it, but you could drop down to a 265 and get a tiny bit of stretch. It won't look like that, lol.
BMWCCA:518970 |
05-31-2015, 07:34 PM | #7 |
459
Rep 2,002
I don't track the car but I hope the ride isn't going to be rough. I also heard these wheels are pretty heavy so I will loose some performance but in my opinion if you go with a 2 piece wheel 19's look to small.
05-31-2015, 09:17 PM | #8 |
Rep 1,017
From 20 inch pretty lite mono block 20 inch wheels to running my 18 inch volk te37 sl's its... a pretty drastic difference. You get so much better response/handling with the smaller wheels as well as being able to run a fatter sidewall.
Even daily driving you will notice big difference, I honestly doubt ill ever put my 20's back on the car.
05-31-2015, 10:27 PM | #9 |
Rep 3,482
Did you run the same type of tire between the 20" and your TE37 SL's? Because usually a smaller sidewall is "better" in response for handling because there's less flex - again, relative to the tires you were using.
BMWCCA:518970 |
05-31-2015, 10:47 PM | #10 |
Rep 1,017
05-31-2015, 11:47 PM | #11 |
Rep 3,482
Right right, but I meant are you running the same type of tire (i.e. summer compound etc etc)
PSS have stiffer sidewalls than most - if not all - contis.
BMWCCA:518970 |
06-01-2015, 03:16 AM | #12 |
Rep 1,017
Ah gotcha,
Iv run the 20s with PSS and Toyo Proxes T1R's. Run the 18's with PSS and Falken Azenis. Falken's as a 200 treadwear tire of course surpass the others but PSS to PSS the 18's just handle/feel better and since thicker sidewall "still lowprofile" its a better ride and much more pothole proof for Wheels. My 20's cost $1600 a wheel, the volks $850 a wheel. Since iv gotten the volks the 20's have stayed in storage, not trying to talk you out of your wheels or anything but.. If id of know how different the wheels felt, not to mention the huge selection of tires you can get for 18's vs the very very limited tires/sizes you can run with the 20's on this car. I would of never purchased the 20 inch wheels. If just for mostly show or looks it does not matter either way
06-01-2015, 03:00 PM | #13 | |
459
Rep 2,002
BTW Car looks great! |
