08-20-2014, 12:23 PM | #1 |
Work hard, play harder!
Rep 27
08 E92 M3 Seatbelt Robot Arm Replacement
They are tired and not grabbing seat belts anymore.
I was wondering if anyone here replaced them before. Where did you get it done and what was the cost? Any input would be appreciated. Thank you!
2008 E92 M3
2010 RAV4 Sport 2013 CBR600RR Repsol Last edited by nutmegchoi; 08-20-2014 at 12:40 PM.. |
08-20-2014, 12:25 PM | #2 |
Rep 27
Also.
My passenger seat's folding handle thingy is a struggle to use. (I'm making things up since I don't know how to call them) Anyone else has the same experience?
2008 E92 M3
2010 RAV4 Sport 2013 CBR600RR Repsol |
08-20-2014, 01:06 PM | #4 |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
There are threads on this. You can replace the ends of the robotic arms as an assembly, and it's a fairly easy job. My car (under waranty) is going in for this very problem in a few days (dealer ordered parts). There is also a BMW service bulletin for some sort of spacer at the bottom of the seatbelt attachment point that alters the alignment of the belt with the hand-off device slightly. My dealer is going to implement the spacers as well. Will post on how that went and if it fixed the problem.
IMO, the condition of the belt itself is a factor. As the belt ages, it softens and that seems to add to the problem. If I take the belt and crease it down the middle in the area where it gets grabbed by the hand-off device, the belt gets picked up almost every time. (Seated in the car, crease the belt lengthwise in the grab area with the folded sides of the belt coming toward you). Guys have done this with an iron and some starch and "fixed" their hand-off issue. I tend to think starching a safety belt could compromise its tensile strength. IMO the belts might need to be replaced to really get this thing working 100%, even with new hand-off devices, but we will see. On older cars, I see this becoming a "more trouble than they're worth" kind of feature. |
08-20-2014, 01:11 PM | #5 | |
Rep 1,637
My car just had both arms replaced under warranty and "spacers" installed. The spacers are essentially rubber surrounds that prevent the base of the seatbelt from traveling along the black metal rail. Sure sure sure. |
08-20-2014, 01:12 PM | #6 | |
Rep 27
Awesome!
Thank you!! Quote:
Most what you said makes sense to me. But wow... it is a lot of trouble for such a little issue... I may need to rethink about this whole ordeal... Thank you so much, guys!!
2008 E92 M3
08-20-2014, 01:34 PM | #8 |
Rep 1,637
08-20-2014, 04:52 PM | #11 |
Rep 4,381
There is a metal bracket that often breaks at the end of the replaceable part. I removed the broken part and the spring that was attached to it and it restored full function.
Its only a 10 min job and nothing to lose if it doesn't work for you. |
