02-17-2016, 08:57 PM | #1 |
Rep 2,476
Drives: Satan's Chariot 2.0
School me on car trailers
Will be in the market for a 1 car open trailer soon. Preferably with a winch.
Anything in particular I should know, do, look for and/or stay away from? |
02-17-2016, 09:10 PM | #2 |
Rep 807
Drives: 2011 335is 6MT
What are you towing with?
02-17-2016, 09:13 PM | #3 |
Rep 179
Drives: Chevrolegs
I picked up a tilt trailer and while it is sweet, it takes some boards to get my car (on KW1 coilovers) on and off without scraping the front bumper
1982 Chevro-legs
02-17-2016, 09:50 PM | #4 |
Rep 2,476
02-17-2016, 09:57 PM | #5 |
Rep 807
02-17-2016, 10:56 PM | #8 |
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
If you have limited towing capacity look into lightweight aluminum trailers. Pricey but the hold their value tenaciously. Trailex, Aluma, Featherlite, ATC, Tommy's. Light trailers are a joy to tow with.
No weight concern, then any $2K steel farm trailer works, look for low deck height or you'll need huge ramps. Torsion axles instead of leaf springs. Wood decks eventually need work. Electric tongue jacks are beautiful devices but overkill on an enclosed. Electric brakes over surge brakes, I like long ramps instead of tilt bed, lockable in-floor spare tire well is a good place for track jack and some tools, removable fenders are helpful for lowered cars with limited door clearance. LED lights because bulbs go out at the worst time. Go for D or even E rated tires, best you can afford, it's worth it as most trailer tires are utter plop. Buy longer bed than you need so you can bring fuel jugs, wheels, tools, pop-up, rig with E track and D rings in the floor. And helps distribute the weight if you ever need it, like ass-heavy 911s. Winch is nice, but not all that needed on an open IMO. I do use a remote winch in my enclosed because it's hard to get out of the car once in. After years of dealing with an open and towing with a car/SUV most eventually end up buying an enclosed and tow vehicle. Enclosed with marine battery inside, solar charging panel on the roof and electric jack is a great set up. I've had my enclosed stolen, full of tools and a pit bike, and many friends have had the same happen. Plan for security based on where your storing it...wheel lock/chocks, hitch lock/vault, chains, gps lowjack etc.
F80 M3 / Mineral Grey-Silverstone / CCB
02-17-2016, 11:24 PM | #9 | |
Rep 807
Even with the newest model optioned out at 3600 there's not enough for a Z06+trailer. Unless you have Forza level weight reduction. |
02-18-2016, 03:37 AM | #10 | |
Rep 111
Drives: BMW M550d G30
02-18-2016, 05:58 AM | #11 |
Bergspyder
1469
Rep 1,212
Budget for a transmission.... You need a tow vehicle.
02-18-2016, 06:07 AM | #12 |
dances with roads
4732
Rep 4,096
02-18-2016, 06:28 AM | #14 |
Rep 2,476
It will be used for towing wrecked cars & such, not my Z06. Either way, if the Caravan can't handle it then it won't be used.
02-18-2016, 09:56 AM | #16 |
Warrant Officer
375
Rep 1,341
Get a vehicle designed for towing (the big 3 250/0+ series, Tundras, ect.). Those vans are only supposed to tow small trailers for light stuff. Just because it's rated for the pounds, doesn't mean you should max it out. Trust me on this, the vehicle makes the difference.
Deleted, ATM I/C and tuned by B.R.R.
02-18-2016, 01:45 PM | #17 | |
Rep 2,476
02-18-2016, 04:03 PM | #18 |
Rep 1,986
Drives: 2014 335i xdrive, 2014 X5 3.5d
Do not use a van to tow. I killed my brothers Sienna transmission towing my boat, $15,000 damage. Had to put in a new tranny. It was even 500 pound below the limit. Got a 4Runner and no trouble towing the boat...
02-18-2016, 05:00 PM | #19 |
Rep 1,602
But used - these things hold their value one they take their new trailer depreciation hit. I have an 18' open hauler. If weight is a concern go with aluminum. Make sure you have a trailer brake controller and don't tow cars with a Caravan. Get a vehicle designed to handle the weight. IIRC my trailer alone is 1500lbs and is an open center design.
Removable/tilt fenders are also a must. Me and some friends converted mine to removable. |
