04-03-2015, 08:17 AM | #1 |
Rep 650
Shift lights outside M mode?
I usually drive in D1 when I'm moving about until I get on the on ramp.... Then it's full M mode S5 and all.... Of course, the shift lights work in M mode, as I have set up ON in iDrive.
I read the manual, and since the setting in iDrive is OFF, ON or UNCHANGED, I'm inclined to think the shift lights work all the time, regardless of M mode. As I have never floored it outside of M mode, can anyone confirm shift lights work with M mode off? Just curious.
Today's gains far outweigh tomorrow's losses.
04-03-2015, 08:23 AM | #2 |
Rep 1,486
Drives: 2012 e92 M3 DCT ZCP
Yes they will, though probably not in D mode.
04-03-2015, 08:24 AM | #3 |
Rep 7,110
Hi JFB,
you can turn shift light on all time in the "M key setting", i.e. optional menu when you are in the main M menu. Here you also can set EDC and Power default in start up. Believe you need to lock/unlock to get the key programmed. And should you use your other key, that obviously might have a different programming. Good luck Edit: Correct, no light in D mode. |
