02-15-2010, 05:37 AM | #1 |
Rep 2,812
Need front tire advice
Hi,
I'm currently running 19x8.5 ET30 front (no spacer) and 19x9.5 ET35 rears w/ 12mm spacer. My current tire set up is 255/35 front and 275/35 rear. I am getting new tires and the 255/35 fronts are out of stock. What is an alternative front set up that will work? 245/40? Any advice out there? Thanks
02-15-2010, 01:07 PM | #3 |
Rep 2,812
Good idea but will there appear to be more wheel gap with the 245s vs the 255s? Trying to avoid that as I am not going to ever lower the car.
Would 265/30 work?
02-15-2010, 01:35 PM | #4 |
Rep 1,084
Drives: 2009 E-90 M3 space gray
Location: Deutschland KreisTrier auf Autobahn 64 & Tucson AZ
265-30-19 wont work your front rim doesn't meet the minimum diamter to safely mount this tire. Plus the overall diameter of a 265-30-19 is 1/2 inch smaller difference than 255-35-19 so it will show a bigger gap.
02-15-2010, 05:25 PM | #6 |
Rep 7,651
265 is simply too wide for the 8.5" fronts.
They usually have rim width range of about 9~10" width rims the 245/35-19 will be perfect. If you'd like, try the RE-11 which would be a little square and nice if you are worried about width and gap. Some tires will have tread width that is wider than others.
