07-20-2014, 12:49 PM | #1 |
Rep 159
Valve Cover Leak!?
I had the gasket on my oil cap give out and it sprayed about a 1 1/4 liters of oil all over my engine which i find out is more common here then one would think. So after cleaning the motor and replacing the oil every time i take it out i see this when i open the hood! It appears the it is weeping form the threads not the gasket! Help and advice appreciated this looks like a big repair. I have the after market extended warranty offered by BMW. If this happen to the cover what about the engine internals!
Jerez Black: 6MT: Lux: 35% Tint: IND gills ,grill , reflectors: K&N Filter: ACM exhaust mod: Dinan pulley
07-20-2014, 02:42 PM | #5 |
Rep 159
That was the first thing i did and the new style cap works great not oil at all around the under side of it. Order one from Turner got it next day!
07-20-2014, 05:17 PM | #6 | |
Rep 1,260
It looks like the leak is at the cover bolt. |
07-20-2014, 08:07 PM | #7 |
Rep 159
The valve cover has the leak under the bolts. Replacing the gasket this week it must have been compromised when it was covered in oil spray when original oil cap seal gave out earlier this week.
07-21-2014, 02:25 AM | #10 |
Rep 1,260
I doubt it. It looks like mine but cleaner. I have leaks in the bolt area and the paint is bubbling up on the valve cover as well ..so i'm planning to take the cover off and repaint. I'll do this the next time I change plugs. I may repaint the cover red.
07-21-2014, 08:30 PM | #11 | |
Rep 159
Car is going to dealership this coming monday since i have 3rd party extended warranty gonna try to get new plugs under it.
07-23-2014, 02:32 PM | #12 | |
General
63357
Rep 24,667
07-28-2014, 06:09 PM | #13 |
Rep 159
Car is at dealership now was told valve cover gasket is covered under extended warranty ($600 plus job- that's just the passenger side that needs replacing )
However the cleaning of under panels and motor WILL NOT be covered ($200) Have gasket on order, I know the plugs to a hit there was oil everywhere! Waiting till they go about replacing gasket to see the extent of the mess on the under side of the plenum. Hoping they will be covered as well just put em in last Fall.
08-08-2014, 02:21 PM | #15 | |
Rep 816
08-11-2014, 04:28 AM | #16 |
Ultimate Driver for the Ultimate Driving Machine
146
Rep 1,146
I got my oil cap replaced twice. once they replaced with a "new and impreved" one for no reason. then i started having the leak issue. so i asked them to put one similar to the older cap. this one works fine. just tell the dealer to give you one. I think they changed them after my2010, i heard less issues with my2010 and earlier
BMW M3 E92 - Silverstone II BPM Sport Stage II Tune + Test Pipes, GTS DCT Tune |
08-11-2014, 06:25 PM | #18 |
Rep 159
