03-03-2020, 05:32 PM | #1 |
Admiral
931
Rep 3,886
Induktiv - Factory Integrated Wireless Charger Review
So I was recently looking at swapping out my center console ash tray with the factory sunglass tray as I pretty much only used the ash tray to store gum wrappers and loose change. I figured it would also be a good spot to keep my phone while driving so I didn't have it between my legs all the time.
Soon into my research, I came across this new integrated wireless charger offered by Induktiv. It looked like a clean setup, and also came with the OEM sunglass tray, so I said why not give it a shot and add even more functionality to my interior. The fit and finish looks factory (as it should considering it uses the OEM sunglass tray), and the charger is actually relatively quick, around +1% per minute. Install was a breeze, just remove the center console, unplug the electrical connectors and simply use the provided connector + resistor and plug straight into the factory cigarette lighter plug under the console. Also, I have personally confirmed fitment with phone sizes up to the iPhone 11 Pro Max with the Silicon Case from Apple, I believe the dimensions are similar to that of the Samsung Galaxy S9 for y'all Android folk. There's still a little room to spare, so if you do have something much larger than that, you may be out of luck, but I think that's plenty of space for MOST phones! For those of you interested, you can purchase here: https://induktivcharging.com/collect...-charging-unit If you already have the sunglass tray, you only need the charger; if not, you will need the charger + OEM tray option. Here's some pics of the charger as well as everything taken apart and put back together: . . . . . . . . What do y'all think? I think it looks factory and fits right in with the interior!
03-04-2020, 10:09 AM | #3 |
Admiral
931
Rep 3,886
Agreed!
03-06-2020, 07:25 PM | #5 |
Admiral
931
Rep 3,886
Yes it does.
03-07-2020, 09:25 PM | #6 |
Save the manuals!
6015
Rep 6,746
Awesome find!
M3ANMACHINE931.00 |
03-09-2020, 10:34 PM | #8 |
Admiral
931
Rep 3,886
The factory sunglass tray removes the whole cover
03-11-2020, 01:52 AM | #9 |
Rep 1,447
Thanks! Just placed an order.
Khalid
'12 BMW E92 M3 '03 BMW E46 M3 '14 Mercedes-Benz S400 '18 Alfa Romeo Giulia Quadrifoglio |
M3ANMACHINE931.00 |
03-11-2020, 06:24 PM | #11 |
Admiral
931
Rep 3,886
Yes charges just like normal. About 1% per minute. Only "issue" I've noticed is that if my iphoneX is on the far right or left edges of the charger it won't charge as the coil is in the middle of the phone and the pad. But it's like a 2-3mm corner so just keep the phone in the middle
SoCalRPM885.50 |
03-12-2020, 09:52 PM | #12 |
Rep 957
very neat and clean solution
M3ANMACHINE931.00 |
03-13-2020, 12:25 AM | #13 |
Rep 709
This is awesome, I might have to pick one up!
Just to confirm, if I have the tray with a cover on it, then I’ll need to purchase the OEM “sunglass” tray with this? |
03-13-2020, 01:15 AM | #14 |
Admiral
931
Rep 3,886
Yes. That's an option under their drop down on the purchase link
04-07-2020, 10:01 PM | #15 |
Rep 2,196
Any additional feedback on this now that it has been a month? Thinking of picking one up.
Bake
2011 Alpine White on Black 535i M-Sport 2013 Space Gray on Fox Red M3 Vert |
04-09-2020, 01:10 AM | #16 |
Rep 1,447
Khalid
M3ANMACHINE931.00 |
04-09-2020, 02:42 AM | #17 |
Admiral
931
Rep 3,886
Nope. Nothing but positive things to say about it. Only quirky thing i noticed with my iPhone X is that if the phone rests on the extreme left or right of the tray the charging coils don't align and the phone stops charging. But it's only like a 1mm space on each side so i just make sure my phone is centered. No problem with a pro max tho
04-09-2020, 08:02 AM | #18 | |
Rep 305
04-10-2020, 05:06 PM | #19 | ||
Admiral
931
Rep 3,886
04-17-2020, 09:53 AM | #20 |
///M
39
Rep 240
Nice product
M3ANMACHINE931.00 |
05-16-2020, 05:44 PM | #21 |
Rep 210
nice one thing I've seen someone else do is get the charging coils separate and just DIY it on the bottom side of the sunglass holder, no need to tap a hold and you can get two coils and wire them up so no matter where your phone sits it will charge. This will be on my to do list. Is there a plug where you plugged the charger into? or is it just he cigarette lighter plug?
here's a link to an extended charger may get this piece and change out the internals to this https://www.amazon.com/dp/B07176HT5T..._e5gWEbVG51JJK Last edited by gh0stE92M3; 05-16-2020 at 05:52 PM.. |
05-16-2020, 10:45 PM | #22 | |
Admiral
931
Rep 3,886
