09-07-2016, 11:01 AM | #1 |
Rep 263
Drives: 2013 E93 M3 Jerez Black, 13 x5
Garage List 2017 GMC 2500HD denali [0.00]
2018 Tesla Model 3P [0.00] 2020 BWM x7 m50i [0.00] 2013 BMW X5 [0.00] 2013 BMW M3 E93 [0.00] |
E93 reporting
Can we get a report of the convertibles and how they are holding?
2013 E93 18,000 miles, 2nd owner No issues with the convertible going up and down Head light did fog up once after washing One or two times small amount of water got into the back seat from washing the car (windows were closed). seal? need to fully open then close the windows before washing? |
09-07-2016, 11:09 AM | #3 |
Rep 1,320
2008 E93
61,000 miles, 2nd owner Top operates smoothly no headlamp fogging all convertible top seals are properly functional, no drips No major issues. Oil Analyses are trending well, no major wear metals (10w60 Liquimoly, 5k intervals) |
09-07-2016, 11:22 AM | #4 |
Rep 263
09-07-2016, 11:44 AM | #5 |
Rep 63
Drives: 2013 E93 M3 LMB, 6MT
Mine's fine... No leaks or strange noises from the top up/down process.
2013, 36K miles, 2nd owner. It needs to be washed and the leather cleaned though. :-) |
09-07-2016, 12:09 PM | #6 |
Rep 692
2008 w/ 82K miles
One top issue - sensor in the rear went out No leaks, no noises, all good Oil analysis is good Enjoy it every time I get in it... When the top sensor went out, it sucked! It was out of the trunk and about to separate when I got a "Top Malfunction" indication and it would not go up or down. BTW - there is no manual way to get this top to move. I read-up on it and found there is a brass bleeder screw on the hydraulic pump that you can back off to let the pressure off. I did that and put it all the way up, although it would not lock. It rattled all over the place until I got to the dealer to have it analyzed and fixed. Was not a good experience! However, that's the only problem I've ever had with the car...
Thanks,
Dave [SIGPIC][/SIGPIC] |
09-07-2016, 12:22 PM | #7 |
///BMW Enthusiast
50
Rep 159
2011 w/ 46k miles
No leaks or noises or problems Oil analysis just came in last month and it's great with the SC kit. Never seen the CEL in it and have had it over a year now.
///2011 E93 VF650 M3 ~VF650 SC Kit - TiAL Q 50MM BOV - GTS Flash - Akrapovic Full Titanium Exhaust w/CF Tips - KW V3 Coilovers - OSS V4 Headlights - ModeCarbon CF GT-4 Lip - ForceWerkz CF Sideskirt Extensions~ |
09-07-2016, 05:10 PM | #8 |
Rep 161
Drives: E93 M3, E86 Z4M, W219 CLS63s
2011 E93
82,000 miles, 2nd owner Convertible top operates smoothly, all convertible top seals are properly functional, no drips at all. No headlamp fogging. Car is daily driven and runs smoothly!
jonesy... |
09-07-2016, 09:35 PM | #9 |
Know's a guy that know's a guy...
5637
Rep 1,905
2013 6MT, 1 owner
20k ESS S/C No problems |
09-07-2016, 11:12 PM | #10 |
Rep 364
2012 w/ 41k miles
Smooth operation of top, no issues other than getting momentarily "stuck" in up position. Greased up the joint/clamps at the top of the front windshield, and hasn't been a problem since. Cables are still good with no fraying. Only other "issue" was related to battery. After hitting a small road bump, car threw all sorts of malfunctions related to seat belt sensor, airbag, etc. had to wiggle the battery safety terminal and clear the codes. No problems since then. Performance-wise car is a champ. Sounds great driving with the top down through a tunnel, with the eisenmann race, test pipes and evolve stage II and DCT tune. Not looking forward to winter |
09-08-2016, 06:07 AM | #11 |
Rep 323
Drives: 2009 E93 M
2009 w/ 59.5K miles. Front cowl motor replaced (for top) one month ago; passenger side window control module replaced one month ago; real left wheel bearing and TPMS replaced two months ago; new battery 8 months ago. Blackstone reports all clear; oil changed every 5-6000 mi. PSR (Personal Stress Reduction) diminished appox. 39-57% upon lowering of top and hearing the V8.
09-08-2016, 12:41 PM | #12 |
Rep 3
2009 E93 DCT
59k miles now Owned since 52K miles Hardtop function started to become intermittent and jerky. Replaced salmon relay in trunk myself and good to go now. Top seals tight and no leaks. Just replaced fuel pressure sensor due to increased emissions code and seem to have fixed the issue. Diagnosed with Carly and replaced myself so cost wasn't too bad. Otherwise it has not had any other issues. Added 15mm spacers front and 12mm rear and upsized tires to PSS 255/275 and have a tiny bit of rubbing but not enough to do anything about. Has Meisterschaft exhaust and sounds amazing with the top down! |
09-08-2016, 01:23 PM | #13 |
Rep 478
2012 E93 DCT
Bought at 30 k miles and now at 46 K miles 5000-6000 miles OCI Will be sending for Oil analysis after 50 k miles. Top started leaking while under warranty. Fixed by dealership. Also sometimes the Lowering function stops in the middle when using the Comfort access key. Other than that the top has been flawless. I maintain it regularly. There is a detailed thread on how to maintain the top just search E93 convertible top maintenance. Car has been running great. Me and my son loves it driving with top down. No issues...touch wood. |
09-09-2016, 12:23 PM | #14 |
Rep 1,198
Drives: 2021 F87 M2c. LBB, 6mt
2008 e93
6mt 28,000 miles My top works great. I was getting 'stuck' when opening it. I lubed up where it meets the windshield and has worked great. The only leaking i get is when I go through a touch-less car wash and the high pressure water hits it. Anyone else have this issue? No issues at all. :::knock on wood:::
2021 F87 M2c. Long Beach Blue over black with blue stitching. 6mt, executive package, slick top.
09-10-2016, 11:56 AM | #17 |
Rep 698
2011
48,000 miles. No issues with the top or any other part of the car except the TPMS just died. I'm going to have new ones installed in a few weeks.
2011 E93 - Space Gray - 6MT/Silver Novillo/
OE Tuning/Gruppe M Intake/ACS Springs/Vorsteiner CF Type I Rear Diffuser/Textured Matte Black Custom Powdercoated OEM 359s/Painted Reflectors/Matte Grille, Hood Vents and Side Markers/Arqray Race Exhaust/MS Pulley |
09-10-2016, 12:38 PM | #18 |
Rep 96
2011
36,000 ,miles no issues other than she is a burner, 1 quart every 1,000 miles approx
99 Vette Vert - Rocket- sold / 10 MDX - Wide DD sold / 15 Fusion Hybrid - Company Car (surprisingly good)/ 15 Tahoe LTZ - Kid Hauler / 11 E93 - My White Beast aka The Mistress
09-10-2016, 01:24 PM | #19 |
BMW CCA member and you should be too!
217
Rep 478
2011
54,000 and some change Original battery Replaced leaking oil engine cap (no charge) Oil change every 7,5K No issues with the top other than the occasional cricking when driving over steep driveways. Applying Gummi Pfledge on all rubber every 6 months. No other issues to report. Just a great vert for fun/value.
