E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > 3.46 Rear Diff from AT on 6MT
      08-06-2012, 12:43 PM   #1
RupertPupkin
RupertPupkin's Avatar
Drives: Freak Beast
I have a 6MT 330i e90. Seems my rear is 3.15. Searching shiows people attempted to swap pumpkins but no one seems to have a definite answer for our platform. Yes, the 335 has had some swaps and LSD etc. Im looking to see what is necessary to swap a non LSD pumpkin from an Automatic to my car. My goal is a budget boost in low end acceleration. I dont track so LSD is both unnecessary, and out of my price I want to spend.
I have seen them go for $300 on Ebay. Curious if it is a direct swap, or a huge pain, etc.
I could care less if my car can hit 155. 99% of my driving is sub 100 and that is where I want to see the benefit.
Thanks.
      08-06-2012, 01:04 PM   #2
VirtuousWolf
Drives: 06 BMW 330i SP
Not sure on your question sorry But I can tell you that my auto diff can hit 155 easily, so I'm guessing you won't have to sacrifice top end speed
Also wouldn't the manual one be better? I mean the manual cars tend to be like .3 seconds or so faster to 60
      08-06-2012, 01:24 PM   #3
RupertPupkin
Drives: Freak Beast
Putting the AT rear diff in the MT allows for even quicker acceleration. It sacrifices top end speed. It all has to do with the gear ratios. Our gears are completely different. Thanks Though!
      08-06-2012, 01:54 PM   #4
Johnny D
Johnny D's Avatar
64
Drives: 2006 BMW 325i
2006 BMW 325i  [9.16]
I remember reading two members did this or a similar swap. One was RichP and the other was ksfrogman or something. See if you can find them to PM them for more info.
      08-06-2012, 01:58 PM   #5
RupertPupkin
Drives: Freak Beast
Great! Thanks for the heads up.
      08-06-2012, 08:46 PM   #6
redlinedbimmer
Drives: 2008 328i 6 speed
the diffs work diff in the automatic and manual cars because the ratios in the transmissions are also different
      08-06-2012, 08:47 PM   #7
redlinedbimmer
in response to virtuous wolf
      08-06-2012, 11:07 PM   #8
VirtuousWolf
Oh wow I learnt something new, so I can go over 155 in my auto, but if you put the same diff in a manual it will go slower?
      08-06-2012, 11:17 PM   #9
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
No, the top speed is governed electronically (149mph for ZSP cars). The diff just changes the final drive ratio. All that means is top speed in each gear will be slower but acceleration faster. You reach the vehicle's ultimate top speed before top gear in either case. Also the rpm for a given speed will higher in all gears. So cruising at 65mph will be around 3300rpm (I think) vs 2700rpm with the standard diff for 6mt cars. Not sure where the auto cruises at.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors
      08-07-2012, 02:13 AM   #10
ladius
Drives: '06 bmw 330i
great to know, thanks!
So sounds like for fuel economy, not so great. I would love the faster acceleration too but I drive a lot for work so I value fuel economy.
      08-07-2012, 09:46 AM   #11
VirtuousWolf
With zsp the limit is 155, in fact it goes past 155 because of "error" and goes faster than that if you delimit it.
      08-07-2012, 12:39 PM   #12
BudVlad
Old Geezer
BudVlad's Avatar
Czech_Republic
360
Drives: 08 E92 N53B30
2008 E92 N53B30  [10.00]
I did the swap and I like it. I used 335i diff and I had to use 335i driveshaft because of the different coupling. At first in top gear BC showed to shift up. After a while it adopted and it doesn’t do it anymore. My gas mileage is slightly worst.
      08-07-2012, 12:45 PM   #13
RupertPupkin
Drives: Freak Beast
Thanks for the info! What did it end up costing you all said and done? Worth it for the improved acceleration?
What ratio did you end up with from the 335?
      08-07-2012, 02:43 PM   #14
BudVlad
Old Geezer
BudVlad's Avatar
Czech_Republic
360
The ratio is 3.46 and the acceleration is better. I didn’t do any measurement before and after. I got the diff and driveshaft from a wrecker in Germany. I think I paid less than $500.
      08-07-2012, 04:45 PM   #15
RupertPupkin
Drives: Freak Beast
Very cool Thank you!
      08-08-2012, 08:20 PM   #16
monza2t
monza2t's Avatar
Drives: E90 328i, R52 Mini, F25 X3 x35
The lowest ratio is from a 328xi (E90) auto @ 3.91. The whole damn thing can be had for about $500.
Going from 3.15 to 3.91 will be a significant kick down low, BUT just remember that the final drive and the gear ratios are fine tuned, so there may be gear or two that seem to be oddly matched.
_____________________________________________
E90 328i Sport & Prem // R52 MINI S JCW // X3 x35i
62 Mini Cooper 997 // 62 Vespa // Laphroaig 30-yr
      08-10-2012, 12:22 PM   #17
RupertPupkin
Drives: Freak Beast
bump
      08-11-2012, 01:00 AM   #18
driverman
Drives: 2008 328i 6MT - SOLD
Thanks for starting this thread.
Changing the diff ratio is the best way to increase performance of our NA E9x, yet there aren't many threads on it.
We can significant increase performance without hurting reliability or increasing complexity. The whole drivetrain runs exactly as it was designed to except the diff sends more torque to the drive wheels.
The only downsides I can think of are cost, worse gas mileage and more engine noise while cruising on the highway.
I look forward to hearing from more enthusiasts that have done it.
      08-16-2012, 04:23 PM   #19
StealYourFace
Drives: F30 328i M 6mt, E36 M3
If you want to really make the car dance and get rid of the one wheel peel, check out Performance Gearing. For $2500 you can swap your oem unit with an LSD. I really like the 3.64 in mine. Plus the LSD helps with hallucinations... I mean makes autocross and driving in the snow a lot more fun
      08-16-2012, 07:48 PM   #20
RupertPupkin
Drives: Freak Beast
Are you 6MT? That ratio seems wild. What rpm in 6th @80?
Edit: Just found your thread. Seems like maybe 3.64 is what I want....hmmmm
      08-16-2012, 11:13 PM   #21
StealYourFace
I'm not 6mt but my car is
It's pretty sweet, why say no when it feels so good to say yes?
      08-16-2012, 11:32 PM   #22
RupertPupkin
Drives: Freak Beast
Haha cool. Sounds like a good diff to get. Appreciate the feedback.
My mind is telling me no.....but my body.....my body is telling me yeeeessss
Tags
3.15, 3.46, 6mt, pumpkin, transmission
e90post
