09-20-2020, 12:37 PM | #1 |
Rep 709
Rotors for Occasional Track Use
I'm looking to upgrade/replace my rotors, and will be doing 3-4 DE events a year on the car. I have PFC08 pads and motul fluid already, but seeing now that the rotors might be the biggest limiting factor.
Question is: Do you go with FCP OE rotors for unlimited replacement, PFC DD V3, Girodisc, the new Tuner rotors, or something else. Was thinking about a BBK but I don't think it's worth the money just yet, and think doing some sort of rotor replacement is the best option, let me know if I'm wrong though.
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL | 85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger |
09-20-2020, 01:03 PM | #2 |
Driver
2692
Rep 2,714
For 3-4 events a year, I'd go fcp oe rotors and run pfc 11 after killing the 08's, for higher temp range vs the 08.
09-21-2020, 12:17 AM | #3 |
Rep 934
+1, this plus FCP's "unlimited rotor" thing means you don't have to worry about wearing out the rotors. Hard to beat imo for 3-4 events per yr. without spending a lot more money.
09-21-2020, 08:29 AM | #4 |
///M Powered for Life
11490
Rep 10,329
A set of PFC V3 will last almost forever. This is likely the same overall effect as an entry level bbk. I've seen cars run in the faster PCA groups with PFC DD rotors without any issues.
The cheapest option for sure is the FCP OEM rotor, however, the OEM rotor does not cool very well and once you aren't a beginner it will not dissipate enough heat. The PFC DD one cools way better so it will allow more pace. At 3-4 days a year it will last longer than the car. |
911r891.00 |
09-21-2020, 08:32 AM | #5 | |
Rep 709
09-21-2020, 08:43 AM | #6 | |
11490
Rep 10,329
The rear sees very little heat compared to the front. I used to track an E46M3. At first the front rotors were hot enough to singe the hair off my leg by standing near them, meanwhile the rears seemed almost cool in comparison. Then I got front PFC DD rotors for the front and immediately the front became cooler than the rears. On the E9X I used a front bbk from the beginning in one of the cars and kept the oem rear, it worked perfectly fine. To make an example, if you are trying to drop 2:08 at VIR you probably need a front BBK. If you aren't there yet, the PFC DD will work great and be more cost effective. |
09-21-2020, 09:10 AM | #7 | |
Rep 709
Thanks!
SYT_Shadow11490.00 |
09-21-2020, 09:53 AM | #8 | |
11490
Rep 10,329
Another advantage of the PFC DD is the pads will last longer than using OEM rotors. They don't have the 'cheese grater' effect and won't reach as high temp as the OEM either. BBKs look cool, but if we were all buying things purely from a utility point of view most people would have the PFC DD rotor and call it a day. |
slowdown_dan285.50 94jedi830.00 |
09-21-2020, 11:06 AM | #9 | |
Rep 5,483
I'd be tempted by that Turner rear setup, but it looks like the same exact hat in the rear as the ECS rotor, just with a slotted ring, which didn't save any weight at all on my car even when cross-drilled. The extra vanes are nice I suppose. I will say, it is absolutely possible to reach the limits of what the rear calipers can handle with good pads and fluid, but you're going to have to be on somethign like a hoosier and you're going to have to be going pretty fast for pretty long. For the casual track dayer, the rear kits are just one of those nice-to-haves to keep the ca rhappy and make pad swaps simple, definiteyl not a must have. The turner fronts seem like a different rotor/hat entirely to the ECS setup, at least look a lot like the AMG Brembo full-floaters. That seems worth trying out, especially for the cost. It's also right in line with what the Brembo replacement front AMG rotors cost. I wonder if somebody has started knocking those off in some faraway land, and has ported it over to other applications that go through a lot of rotors/upgrades.
09-21-2020, 11:09 AM | #10 | |
Rep 709
I just wish I could grab a pair of slotted rears to match the fronts. I'm about to pull the trigger on some Girodisc fronts from Bimmerworld, and most likely just OEM rears from FCP unless there's another option.
09-21-2020, 06:27 PM | #11 | |
Rep 146
09-21-2020, 06:34 PM | #12 | |
Rep 709
Let me know if you find the DD’s as if the above is correct then I’ll need a set as well. |
09-22-2020, 11:46 AM | #13 | |
Rep 146
Hope this helps! Rubin |
09-22-2020, 01:14 PM | #14 |
Rep 3,988
how much are the replacement rings and where can you buy them?
09-22-2020, 02:11 PM | #15 |
Rep 5,483
Unless something changed, ECS is not doing replacement rings. You can buy a new set (hat and ring assembly) for a $50 discount or something, last I checked.
I'm not sure I have a big issue with this - replaceability isn't such a big concern for me, but cost is, and this doesn't save much cost vs. rotors that DO offer replaceability.
09-22-2020, 05:14 PM | #16 | |
Rep 934
09-22-2020, 06:49 PM | #17 | |
11490
Rep 10,329
The PFC DD would last forever if you only use it for the track. If you use it for the street as well eventually you'll wear it down the way OEM rotors get worn on the street. It's at the track where you really see the durability difference due to the superior metallurgy of the PFC rotor -machined with no oils whatsoever- and the superior cooling of PFC vs OEM. Girodisc is also good. If I had the choice I'd still buy PFC, the rotor is simply better full stop, but PFC is pulling back from the aftermarket and may not be available. If it is not, Girodisc is the way to go. That BW now offers Girodisc vs PFC tells me that point has already arrived, unfortunately. Unfortunately PFC built the best stuff but if you can't buy it then it's time to move to the next best thing. So sad. |
911r891.00 |
09-23-2020, 08:40 AM | #18 |
Rep 709
Just as an update, my Girodiscs are shipping out and will be here in a week. So not sure if I got the last pair or if maybe you got the wrong information. Hopefully this doesn’t jinx it, but I’ll update when I actually have the rotors on my doorstep.
09-23-2020, 08:42 AM | #19 | |
Rep 709
09-23-2020, 09:04 AM | #20 | |
11490
Rep 10,329
Anyway, Girodisc is still good quality, you will be good to go! |
09-23-2020, 11:55 AM | #21 |
Rep 146
09-23-2020, 11:57 AM | #22 | |
Rep 146
"Ready for a re-ring? ECS offers discounts on pairs of replacement rotors to the original customer or customers showing proof of ownership. Please contact the Sales Department for additional information." |
Tags |
brakes, girodisc, oem, pfc, rotors, track, turner |
