      09-15-2015, 02:17 AM   #1
Johnny250
Drives: 328d Wagon
Pre lci to lci trunk conversion
So I got everything on, minus the trunk stops (how the hell do you get those out), but I'm having problems adjusting the trunk. It just doesn't seem to shut easily at all. Just wondering how much adjusting everyone had to do when converting from a pre lci to lci e90 trunk?
      09-15-2015, 09:47 AM   #2
whats77inaname
Drives: when at all possible
None, it fit perfectly w/no adjustment. Congratulations, BTW.
      09-15-2015, 10:28 AM   #3
Johnny250
Drives: 328d Wagon
thanks.. wish mine fits perfectly.
      09-15-2015, 05:23 PM   #4
whats77inaname
Don't worry, my man, it'll get there. Is it catching on the truck lock latch? Can you get some pics?
      09-15-2015, 10:40 PM   #5
Johnny250
Drives: 328d Wagon
I took off the latching mechanism and just try to get the trunk down. The left side won't go down enough to be flush with the quarter panels but the right side is easy. Maybe the trunks fitment sucks? It's an oem trunk..
      09-17-2015, 10:03 AM   #6
bluehydros
Drives: 08 AW E90 M3
There are two plastic rivets holding each trunk stop in. You have to carefully push them in until they pop out of the trunk stop. Then, just pull the trunk stop off and fish for the plastic rivets inside the trunk. Reverse steps to install on new trunk lid.
      09-17-2015, 10:09 AM   #7
Johnny250
Drives: 328d Wagon
thanks, i actually got these out last night by just going at it with a flathead.. it worked for the most part.
so i got the trunk fitting better but it still sits a little to the left.. should be an easy fix but im afraid that if i adjust it again ti might get worse lol.
      09-17-2015, 11:40 AM   #8
Dumpspec
Drives: @dumpspec
you will have to re wire the the brake light harness. When i installed my trunk the lights were all wonky and stuff haha.
      09-17-2015, 12:32 PM   #9
dlaw
Drives: E90 M3
I literally just did this two weeks ago and took a few tries before everything lined up. It was kinda frustrating because I did an OEM swap as well and was surprised it didn't line up from the start.
You know where the bracket bolts onto the truck itself? Loosen those up so that the trunk slides a bit side to side and forward and back. Now slide it to either direction, open and close it a few times, then make the proper adjustment before you tighten it down.
I never had to play with the bump stops. What issues are you having with those?
