05-11-2011, 10:22 AM | #1 |
Rep 277
KW's Plastic spring perches?
So I just installed KW Clubsports (thanks to Julius@wheelsto) on my M3 and there are a few things I noticed. On the plus side, the bump adjustment is now an adjustment knob and not the small allen bolt that I've seen in pictures. Same goes for the rear, maybe the old ones here knobs too, though. But the one thing that I noticed (and I couldn't tell from pictures) is that the front spring perch is made of plastic. That kind of scares me to be honest.
A simple google search brought me to 2-3 stories of the spring perches either stripping or failing. I also found (through google search) that the spring perches aren't really made of plastic, but rather aluminum with a plastic coating. It's not only the current ones, either. I've seen some posts on here from maybe 2008 on a V3 install and it too had plastic perches (looks just like mine). They are also plastic looking on some Clubsports I'm looking to get for my S2000 as well. Can anyone chime in here? KW maybe?
05-11-2011, 11:28 AM | #2 |
Moderator
673
Rep 4,737
It's polyamide. Used to reduce NVH. The Clubsport, after all, is street biased and designed for 70/30 street/track. KW does offer full aluminum perches you can install on your CS from their competition line if needed.
05-11-2011, 11:56 AM | #3 |
Rep 2,991
I've only seen KW perches fail with heat. I know a few race teams that found them to not work because of their inability to resist high temperatures... For street and mild track use (ie most mortal drivers) you're not really going to have a problem, because from a material perspective, they are as hardy as the typical aluminum perches.
05-11-2011, 06:48 PM | #4 | |
Rep 3,882
05-11-2011, 08:14 PM | #5 |
Rep 277
Cool! It looks like I would need special spanner wrenches for these. Does that sound right? If so, is this also something I can get from KW?
05-11-2011, 08:15 PM | #6 |
Rep 277
I'll have to check when I have access to my camera.
05-12-2011, 06:30 PM | #8 | |
Moderator
673
Rep 4,737
You can purchase the perches/collars from any distributor of KW Competition products. |
05-13-2011, 01:34 AM | #9 |
Rep 277
Got a chance to look at the pics I took and none of them show the bottom adjustment knobs very well. Sorry!
