01-30-2014, 04:54 PM | #1 |
Rep 220
Main bearing question
Looking for some help from engine builders or anyone that has some knowledge of this. I'm trying to place an order for the rest of the parts to rebuild my 08 s65 and I don't quite understand which main bearings I need. I thought I just need to order the based on the letters on the crank and the block but in this work shop manual it says I need special repair bearings marked with (R) on the back which through all the reading I have done on this have never heard of.
this is copy and pasted. my motor would fall under the first statement worn case worn crankshaft. Important! 1. Repair crankcase worn St.0 or 1 / crankshaft worn St.0. If the bearing channel is opened and closed again after engine operation, all main bearing shells must be replaced with special repair bearing shells. Altered settling behaviour at the crankcase. Repair bearing shells are marked with an (R) on their backs. 2. Repair crankcase worn St.0 or 1 / crankshaft new St.0. Repair bearing shells marked with (R) must be used. The crankshaft comes as a set together with the bearing shells. The bearing shells for the bedplate are provided in accordance with the crankshaft classification. For the crankcase bearing shells, the green bearing shells are always provided. The half classification is retained. 3. Repair crankcase new St.0 or 1 / crankshaft worn St.0. The bearing shells also designated for initial installation must be used. The crankcase comes as a set together with the bearing shells. The bearing shells for the crankcase are provided in accordance with the crankcase classification. For the bedplate, the green bearing shells are always provided. The half classification is retained. 4. Repair crankcase new St.0 or 1 / crankshaft new St.0. The bearing shells also designated for initial installation must be used. The bearing shells provided with the crankcase must be used. The crankcase comes as a set together with the bearing shells. The bearing shells for the crankcase are provided in accordance with the crankcase classification. For the bedplate, the green bearing shells are always provided. The half classification is retained. So I went and checked realoem.com: 01 AT-CRANKSHAFT WITH BEARING SHELLS 1 11210443639 $2,504.51 02 Bearing shell green 70,00MM(0) 4 10/2008 11217841489 ENDED 02 Bearing shell green 70,00MM(0) 4 11217841610 $31.17 02 Bearing shell yellow 70,00MM(0) 4 11217841609 $31.17 02 Bearing shell violet 70,00MM(0) 4 11217841611 $31.17 03 GUIDE-BEARING SHELL YELLOW 70,00MM(0) 1 10/2008 11217841498 ENDED 03 GUIDE-BEARING SHELL YELLOW 70,00MM(0) 1 11217841617 $114.39 03 GUIDE-BEARING SHELL GREEN 70,00MM(0) 1 11217841618 $114.39 03 Guide bearing shell violet 70,00MM(0) 1 11217841619 $114.39 04 Bearing shell yellow 70,00MM(0) 4 11217841605 $31.17 04 Bearing shell green 70,00MM(0) 4 11217841606 $31.17 04 Bearing shell violet 70,00MM(0) 4 11217841607 $31.17 05 Guide bearing shell violet 70,00MM(0) 1 10/2008 11217841495 ENDED 05 Guide bearing shell violet 70,00MM(0) 1 11217841615 $114.39 05 GUIDE-BEARING SHELL YELLOW 70,00MM(0) 1 11217841613 $114.39 05 GUIDE-BEARING SHELL GREEN 70,00MM(0) 1 11217841614 $114.39 06 Bearing shell, blue 53,00MM(0) 8 11247841703 $25.12 07 Bearing shell, red 53,00MM(0) 8 11247841702 $15.49 08 Dowel D=14,5MM 1 11211736881 $2.87 Nothing here about special repair bearings at all. I reall don't want to order form my local stealership because their prices are absolutely outrageous even for bmw dealers. The next question I have or more of clarification. The block that is being used has GGVVV which from what I can tell, tells you which upper shells it takes no. 2 on the diagram below. Which letter indicates the guide bearing no.3 below? I am assuming the last letter V but I don't want to end up with the wrong one. The crank that is being used has GGGYG which should be the lower shells. so same question which are the letters in order as they are in the picture? or is there something maybe in BMW TIS that I can't find? Thank you in advance for any help. Also if any vendor can beat online prices on all the gaskets and bearings needed for a rebuild that would be greatly appreciated send me a pm. I added a carnage shot of my rod bearing failure for fun eventually I will get around to posting a full thread. |
01-30-2014, 05:02 PM | #2 |
Rep 1,673
Regular Guy has rebuilt many and can help you on specifics.
02 Bearing shell green 70,00MM(0) 4 10/2008 11217841489 ENDED 02 Bearing shell green 70,00MM(0) 4 11217841610 $31.17 02 Bearing shell yellow 70,00MM(0) 4 11217841609 $31.17 02 Bearing shell violet 70,00MM(0) 4 11217841611 $31.17 The bottom number is all that is available as the top numbers are no longer made. It makes it look like there are a bunch to choose from but that is not really the case. Tough luck about the failure. If the crank is already out I would get with RG about some that he has with built in extra clearance. Just a thought.
Electronics Junkie, Engine Builder.
01-30-2014, 05:24 PM | #3 |
Rep 220
I figured RG would be the one to talk to about this. The crank is out. the original plan was to have the crank resized to correct spec. But unfortunately at the moment I need to get this project done as possible and as cheap as possible considering my current financial position. Down the road im hoping to build a stroker motor.
The plan is to go to M1 0W-40 once rebuilt do you have any suggestions as fas as break in oil? I hear people go with rotella not sure what weight. But word is standard fill is TWS. thanks for your help |
01-30-2014, 05:45 PM | #4 | |
Rep 1,673
01-30-2014, 08:46 PM | #5 | |
1119
Rep 7,690
Shoot me a PM and I can help you as well. RG knows his stuff ! |
01-31-2014, 12:27 AM | #6 |
Rep 1,947
Ack, I'm on the spot now. I'm not an engine builder!
I've never heard of the rebuild bearings. They're only one set of part numbers in the catalog. Most engines I've seen were GGGGG, but I did see one GGYGG. And yes, that one had a yellow shell in it. The bearings are spec'd from the journal sizes. The specs are as follows: Yellow = 59.984mm (-0.000mm, +0.006mm) Green_ = 59.977mm (-0.000mm, +0.006mm) Violet = 59.971mm (-0.000mm, +0.005mm) Here's how I think you can do it. Measure your main journals. If your journal is: 2.36155 - 2.36180 = Yellow 2.36130 - 2.36154 = Green 2.36105 - 2.36129 = Violet Less than 2.36104 = Get your crank fixed. |
01-31-2014, 06:57 AM | #7 | |
Rep 220
01-31-2014, 06:59 AM | #8 |
Rep 220
01-31-2014, 07:04 AM | #9 |
1119
Rep 7,690
02-05-2014, 12:13 PM | #10 | |
Rep 1,947
