      04-07-2014, 03:30 PM   #1
Rob_O
Daily Driver
Rob_O's Avatar
Drives: 2019 RS5 SB | 2020 F83 M4
Looking for second opinion on c/o install ...
Had KW V3s installed on my E93 last week. Despite clearly explaining how I wanted the ride height set -- and stating outright I wasn't looking to have the car "slammed" -- the installer set front and rear "as low as they'd go."
The front is way too low -- for my taste, and daily use -- so I have to bring it back in to have them level it a bit this week. However, they're stating this is as low as the rears will go. It looks damn near stock, if not higher!
Compare with this E93 from EAS on stock suspension ...
Mineral White E93 M3 Work Emotion CR Ultimate 05 by european auto source, on Flickr
I confirmed prior to install the kit (purchased new from the shop installing them) that it was an E93 fitment, although I didn't see the box/packaging and don't have my jack to get under the car for part numbers. Even so, compared with the E93 below from EAS which is running V3s, clearly it can be set lower.
They also incorrectly installed the rear headlight adjustment sensor ... So my low beams point right in oncoming driver's LOS, blinding them.
Thoughts from the E9x coilover brain trust?
Mineral White E93 M3 Vorsteiner HRE KW 7 by european auto source, on Flickr
      04-07-2014, 05:26 PM   #2
M3PO
M3PO's Avatar
84
Drives: '08 IB E92
Front looks good. Rear is 4x4. I DD mine with a lip that low no big deal.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R
      04-08-2014, 09:27 AM   #3
THE TECH
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
Doesn't look slammed to me at all.
      04-08-2014, 09:31 AM   #4
Bavarian Beast
Too many wagons on the bahn.....
Bavarian Beast's Avatar
98
Drives: LMB 2011 BMW e93
Looks ok to me.
      04-18-2014, 10:31 PM   #5
Articsilber323
Articsilber323's Avatar
18
Drives: Bmw
i would lower the rear some more if it was mine, leave the front alone
      04-19-2014, 10:50 AM   #6
Rob_O
Daily Driver
Rob_O's Avatar
All sorted. Installer had the rear springs inverted. Sits perfect now (for my taste).
