04-19-2021, 09:31 AM | #1 |
Rep 107
Drives: E93 M3, Melbourne Red, 6sp
DIY: E93 Roof Drain Cleaning (Convertible, Origami Top)
Greetings fellow e93 owners!
This is an important PSA for E93 owners. These roof drains are often overlooked until it's too late. Front drains can leak into the cabin, and rear drains can flood your trunk (and damage all of the electronics stored in the lowest areas ). This is a starting point, and I will add photos/videos next time I do it. Front Convertible Roof Drains: When the top is down, you will see them at each corner at the “top” of the windshield. This Youtube video shows them early on in the video: . I use a 1/4” trombone cleaner to clean them, while some use a hose or compressed air. Note that it drains from the bottom of the A pillar and will splatter nasty crud when the door is open. I usually put a bucket or piece of plastic to cover the door/door jam. Rear Convertible Roof Drains: The drain plug is located behind a small trim panel directly in front of each rear wheel. Remove the plastic trim piece first in order to access the drain plug, which is held on with 2 plastic T30 bolts and 3 tiny push through rivets to get it off. Once that trim is off, use a 14mm socket to free the plug’s pins by loosening a 1/8 turn then pull it down to get it out. Don't force it more than that or you risk breaking the pins. Here is a video of someone else doing it, but please note that he improperly rips the drain plug out and I also would be nervous sticking a garden hose up into the drain like he did. This is a starting point, and I will try to update with photos/videos next time I do it.
'08 E93 M3, 6 speed
Melbourne Red Metallic with Fox Red Interior. BE Bearings / BE-ARP Bolts @ 57k miles by Active AutoWerke (12/2020) Active Autowerke Pulley, Tune, and drop-in Filter. Full Akrapovic Evo Exhaust (dual resonated with secondary high flow cats). Last edited by Pappas Fritas; 04-19-2021 at 09:45 AM.. |
04-20-2021, 04:38 PM | #4 |
Rep 107
Happy to share the info, helps all of us to share and collectively comment in one location! I'll update this with photos next time I clean them.
These drains are specific to e93s. There may be other drains specific to e90/e92, ie sunroof drains. Someone else will need to chime in. Fyi, There are 2 drains in the engine bay that all e9x M3s have, close to the windshield. They have a small baskets in them to stop leaves from falling in.
'08 E93 M3, 6 speed
Melbourne Red Metallic with Fox Red Interior. BE Bearings / BE-ARP Bolts @ 57k miles by Active AutoWerke (12/2020) Active Autowerke Pulley, Tune, and drop-in Filter. Full Akrapovic Evo Exhaust (dual resonated with secondary high flow cats). |
jdamore435.50 |
07-13-2021, 08:28 AM | #5 | |
Rep 26
Unfortunately I couldn't get to free the plastic plug's pins. A 14mm socket doesn't fit as it was too small, and I couldn't find anything suitable to turn it to loosen it. I had to use the method in the video, yanking it off with pliers The good news however, was that not a single drop of water came out!! |
Pappas Fritas61.50 |
Tags |
convertible hard top, convertible roof, drain, drain plug, e93, e93 cabrio, e93 convertible, e93 diy, e93 routine maintenance, roof drain |
