06-10-2008, 12:04 PM | #1 |
Rep 56
DCT buyers beware!!!
Long story short...At the 1200 mile service dealer put in wrong tranny fluid. Dealer says they did what BMW instructed them to do. Tranny starting slipping and whining soon thereafter. Dealer's had the car for a week and changed the tranny fluid out with the new stuff per BMW and is delivering the car today. BMW corporate says no new tranny, no extended warranty, no nothing. They will not do anything else. BEWARE if you need anything from BMW. They suck!
06-10-2008, 12:09 PM | #2 |
Moderator / European Editor
1494
Rep 6,755
You're not the first this has happened to. Have a look at this:
http://www.m3post.com/forums/showthread.php?t=142347 Davo's transmission has been changed, though. This is what you should ask for also. Best regards, south
06-10-2008, 12:19 PM | #4 |
Rep 1,161
hmm something is not right. BMW knows that the 6mt fluid damages the DCt. They have already replaced a few trannies due to this issue. Why wouldn't they replace yours.... clearly the dealer made a mistake since they where probably to busy pushing your car to the limits to read the TSB.
are you a troll from the 6MT club |
06-10-2008, 12:21 PM | #5 |
Reincarnated
245
Rep 4,227
06-10-2008, 12:24 PM | #6 | |
Rep 5,498
Jason
Instagram: jellismotorwerks |
06-10-2008, 12:26 PM | #7 |
1494
Rep 6,755
Totally uncalled for! The guys's got a problem and asks for help. Relax and stop stating such assumptions.
Best regards, south
06-10-2008, 12:34 PM | #8 |
Moderator
7509
Rep 19,370
I'll bet BMW does not eat 100% of the cost for the M-DCT boo-boos. It makes sense given that there was indeed a memo sent out. Part of the liability is likely to lie with the dealerships.
And guess what? Your dealer has apparently decided they don't want to own up to their share of the mistake. You need to make sure that both they and BMW USA know that you are aware that others have had their transmissions replaced for this exact same issue. And make sure it is you who talks to BMW USA, don't let your dealership be the middleman, and do not believe anything they say unless you can prove it to be true. |
06-10-2008, 12:39 PM | #9 | |
Rep 1,161
Guys - Please lighten up. My post was not offensive. It was a serious but light hearted question. Like the rest of my post stated, it did sound a little suspicious that BMW would damage a car by means of the wrong fluid and then tell the customer to F off. |
06-10-2008, 12:42 PM | #10 |
Rep 3,303
+1
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
06-10-2008, 12:44 PM | #11 | |
Rep 3,303
Do you know whether they are not changing the fluid at all (as I have read) or they are now changing the fluid but with the M-DCT Fluid versus the 6MT fluid?
06-10-2008, 12:55 PM | #12 |
Rep 3,384
This confirms it. Most BMW techs are fucking morons. Lesson learned, bring the TSB and shove it in their faces. Hell, when I take my car in I will demand to be with the car as it is serviced.
06-10-2008, 12:55 PM | #13 | |
M
9
Rep 211
06-10-2008, 12:59 PM | #14 | |
M
9
Rep 211
Good luck all. Last edited by Mx3; 06-10-2008 at 02:12 PM.. |
06-10-2008, 01:04 PM | #16 |
Rep 655
Drives: Gone- 08 DCT SSII, 2006 SMG
Location: Current: 2014 BMW 4-Series Convert for the fiance w M Package, F150, 06 S2000, 08 911 c4s
insane that this is still happening.
2008 SSII DCT M3/Peapack/Parsippany NJ
06-10-2008, 01:14 PM | #18 | |
Rep 1,161
+1000000000. Can you belive the nerve some people have In any case, couldn't find the TSB but this may help Publish Date: May 13, 2008 Expiration Date: July 13, 2008 Subjct: M3 Dual Clutch Transmission Fluid E90, E92 and E93 M3 vehicles can be equipped with a Dual Clutch Transmission (DCT with M Drivelogic), Option Code 2MK. This new transmission requires a special lubricant/hydraulic fluid referred to as BMW DCT OIL 1. This is an extended-life type fluid which DOES NOT require maintenance (replacement). Currently the fluid is not available via your Parts Distribution Center. Until further notice, when DCT OIL 1 fluid is required, enter a PuMA Case and wait for a responce. |
06-10-2008, 01:36 PM | #19 | ||
1494
Rep 6,755
As gagdet mentioned, DCT fluid is an "extended life type of fluid" which does not require to be changed. Best regards, south
06-10-2008, 01:37 PM | #20 |
Rep 1,973
Here: http://www.m3post.com/forums/showthr...ght=blackberry
I remembered the OP mentioned his blackberry. Haha. EDIT: Oops ... south beat me to it.
MDCT ... so you can drive and eat a hamburger at the same time. |
06-10-2008, 02:00 PM | #21 | |
Rep 99
Have you discussed the specific cases on this board with your service advisor or BMW NA? Can they explain why numerous people here got new transmissions yet you are not? Also, I would not trust your dealer to do the right thing on their own. Get BMW NA involved and talk directly with them. It could be that the dealer realizes they are going to be on the hook for this, and they are telling you that a fluid change will fix it when they haven't even spoken to BMW NA.
2015 Austin Yellow M4
2014 McLaren 12C Spider 1969 Porsche 912 Targa |
06-10-2008, 03:10 PM | #22 |
Rep 1,247
Drives: E60 M5, E71 X6M, E46 M3
Garage List 2006 BMW E46 M3 'vert [0.00]
2008 BMW M5 [0.00] 2011 BMW E92 [0.00] 2012 BMW X6M [0.00] 2003 E46 M3 [0.00] |
My thoughts from before are here:
http://www.m3post.com/forums/showpos...&postcount=168 My inclination is that since it is a stealership mistake...that they are on the hook for the cost of the repair...not BMW Can someone with knowledge of how a new car stealership works please chime in???
Current: 2006 E46 M3 'vert 6-sp 2008 E60 M5, 2011 E92 328 6-sp, 2011 E70 N55, 2012 E71 X6M
