04-26-2017, 08:36 PM | #1 |
Rep 21
steering wheel shimmy
all,
08 e93 with minor steering wheel shimmy. also when top is down and i hit bumps it feels like the front of car is flexing and not being absorbed by suspension and creates almost like a reverberation. weird thing is on a new piece of road close to home it doesn't shimmy. most would say balance or bent wheel but why would it go away on perfect road??? its not like the regular roads are bad to begin with. please help |
04-26-2017, 10:23 PM | #2 |
Rep 183
Sounds like control arm bushings or tie rod ends
08 E90 M3 - 6MT, Interlagos Blue, no moonroof, tech package, carbon trim, silver interior.
04-26-2017, 10:27 PM | #3 |
Rep 86
not sure how bad yours is.
Mine vibrates subtly when cold in the morning at around 80 mph, after car is fully warmed up(tires were probably warmed up too), vibration is then very little. I just think it is normal cuz almost all the performance cars are like this: 350z, evo x, etc. |
04-27-2017, 06:20 AM | #4 |
Rep 21
Thanks guys but why on the perfect piece of road would it stop? Would the bushings and tie rods prevent that but since the road is so nice it takes the stress off those components and stops the shimmy?
04-27-2017, 07:02 AM | #5 |
F15 daddymobile
2341
Rep 3,507
this is definitely too difficult to diagnose via forum. if anything it could control arm mounts, or any type of bushing on the suspension pieces. how many miles are on the car?
04-27-2017, 10:22 AM | #7 |
Rep 21
Would front shock or fatigue cause this issue???I also get a jerking in the wheel when turning into my driveway seems like the car isn't absorbing the bumps correctly just a thought because I am getting that reverberation when I hit bumps when the top is down
04-27-2017, 01:11 PM | #9 |
Rep 541
For a start check/confirm proper tire pressure all around.
This can make a noticeable difference, even if it's within the tolerances of the monitoring system. After that you can run down ideas above. |
04-27-2017, 01:30 PM | #10 |
Rep 1,930
The tolerances on these vehicles suck and can be anything from a bad wheel balance, to a worn bushing. OP I would check first in the obvious places before you start going into your suspension. Jack the car up and try to wiggle your wheel to see if there is play.
04-27-2017, 03:30 PM | #11 |
Rep 1,326
Could be anything. Biggest culprit is usually unbalanced wheels/tires. Then move on to bushings/tie rods.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
04-27-2017, 03:38 PM | #12 |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
+1 on this... When I bought mine it had a steering wheel vibe above 70 mph that I fixed by having my alignment shop do a front tire re-balance using a Hunter Road Force balancer. Never had a problem since. Sometimes when a road is cambered or off level, the pre-load you are applying to the steering wheel to keep the car straight cancels a minor shimmy.
05-12-2017, 08:23 PM | #13 |
Rep 21
All.
I just bought new rims and had them all road forced and balanced all the tolerances were all 11 and 12. This did improve the shimmy but it still didn't go away fully. My next move is to align the car and go from there. This is very frustrating. I can not believe I can't figure this out. Could it be an alignment issue even with no signs of uneven wear? Is an alignment worth getting ? At this point I want to eliminate as many easy or obvious variables as possible |
05-12-2017, 11:19 PM | #14 |
Rep 2,907
Drives: 2011 E93 M3
If shaking only occurs with the top down then I would suggest that you're feeling "cowl shake". Its very prevalent with convertibles (of any make) when the top is down. The top adds rigidity to the body when it's up so you don't notice it until you drop the top.
The steering wheel shimmy could be anything from brake rotor deposits to worn bushings. Something like that will probably need in person diagnosis. |
05-13-2017, 12:40 AM | #15 |
Rep 86
Honestly, man, if it is not too bad, just give up and enjoy the car.
I tried to debug the issue 2 years ago with my Evo X, which I felt was extremely picky in terms of wheel balance and alignment, probably due to the fact that it was a AWD car. I spent money multiple alignments, wheel balancing and have it checked by multiple shops, probably cost me over 700 bucks for nothing in the end. |
05-25-2017, 11:37 AM | #16 |
Rep 21
Temerature!!!!
All if you have been following this thread you know I've been battling with steering wheel shimmy. I live in Buffalo New York and the past two days have been 80° when I took the car out there was absolutely no steering wheel shimmy at any speed which leads me to believe that my tires which are Toyo T1 sport that the temperature has everything to do with the drivability of the tire. Has anybody ever encountered this?
05-25-2017, 12:49 PM | #17 | |
Rep 86
My tires , hankook v12 , are known to be soft, and probably flat spot easily. Fully warming up the tires/ warmer temp helps. |
05-25-2017, 01:05 PM | #18 | |
Rep 1,325
