07-22-2009, 05:11 AM | #1 |
Rep 330
Downshifting question DCT
Is it possible to downshift directly from, say, 5th gear to say, 3rd or 2nd in one move?
Also, do most of you guys downshift as you approach a stop or do you just let the DCT do it for you (while in S mode). |
07-22-2009, 05:15 AM | #2 |
BMW Freshman
11
Rep 82
As part of an automated design (Anti-Stall I believe was the term, but not positive), the DCT can downshift more than one gear, but not manually so far as I know.
07-22-2009, 05:20 AM | #3 |
Rep 49
From my experience yes one can downshift more than one gear.
Now: E92 M3 Alpine White, Past: RS4 (sold for E92 M3)
997 GT3 (regrettably sold for E60 M5), 996 GT2 (not as pure as GT3), Evo X, 1098R, GTR (tranny paranoia) |
07-22-2009, 05:26 AM | #5 |
Rep 4,381
You can fast multi click on the downshift paddle if you want to swop from say 5th to 2nd, but I'm not convinced that the command is always handled well by the system (possibly as a result of the way the DCT tries to have the next predicted gear ratio preselected). My preference is always to single downshift, you can string a series of downshifts together very quickly without issue even under heavy braking.
You can let software do the the anti-stall downshifts as you approach a junction but you risk the DCT being in the process of making a downshift when you want to reapply the power which can leave you with no drive for a short time (dependant on which software version your car has). If you make the downshifts yourself, the downshift is quick and certain, the higher the gearshift mode (s1->s6) the more rev matching you get = faster downshifts, whereas in S1 you can heel and toe during the (what would otherwise be a slow) downshift to produce a fast downshift (my favourite and default daily driving gearbox mode). |
07-22-2009, 05:29 AM | #6 | |
BMW Freshman
11
Rep 82
07-22-2009, 05:47 AM | #7 |
Rep 4,381
I don't know whether the hardware can physically skips gears or if it has to go through every downshiftshift squentially.
I do sometimes make multi-downshifts but I don't like the time it takes to execute them which doesn't always seem constant or predictable. |
07-22-2009, 06:22 AM | #8 | |
Rep 49
07-22-2009, 08:14 AM | #9 | ||
Moderator
7509
Rep 19,370
Granted, this does not provide a way to do a multi-gear downshift on deccleration. I just use multiple paddle pulls for that. Quote:
You talk about this often, SFP, and it intrigues me. I never drive in S1. To me, heal-toe is a process that requires the ability for the engine to free rev momentarily, either while the transmission is in neutral (double clutch) or the clutch is simply disengaged (single clutch). Its not clear to me how or why the transmission can allow this in the context of the heal-toe process. But, as I say, it does intrigue me. Can you explain how this all works from a DCT-operation perspective? |
07-22-2009, 09:18 AM | #10 | |
Rep 4,381
Its more toe and toe than heel and toe in the sense that I cover the brake and throttle with the wide part of my shoe and just rock my foot to the side to push the throttle. Even a tickle is enough to transform the otherwise slow S1 downshift into 2nd or 1st into a quick smooth downshift and a confidence that you are in the gear you want. I've just come back from a quick drive where I found you can indeed make quick multigear downshifts...the higher the gearshift mode the better it works..in S6 I managed 7th to 2nd in one shift but if you try it yourselves you do need be at low revs in 7th as it will rev match the shift up to rev limit if it can. The only thing I noticed was that when I didn't click the paddle quick enough it went from 7th to 3rd and then 2nd but it was still pretty quick. |
07-22-2009, 09:31 AM | #11 |
Rep 1,172
Why do you need to click the " - " paddle repeaditly many times in order to downshift multiple gears instead of pushing the gas beyond the kickdown pont and click the " - " paddle once? The system will downshift as many gears as needed (and have the engine rev matched) instantly to get you to the optimal gear for max acceleration at any given speed, eg from 7 to 2nd if needed. Why do you need to click the " - " paddle 5 times to achieve the same result?
07-22-2009, 09:39 AM | #12 | ||
Moderator
7509
Rep 19,370
But it was never clear to me whether the transmission was genuinely skipping gears in the process. That is, are the shift collars moving around inside the transmission in preparation to shift into each of the gears you pass through? Or is there enough of a delay built into the system such that it holds off even starting to execute the gear change until no more downshifts are detected? I guess it doesn't really matter as long as you get the effect of a multi-gear downshit. But I do sometimes wonder about wear, if the former is really what is going on inside. Because of that, I do still sometimes wish there were a way to do a true single-pull multi-gear downshift on deccelertaion like you can when accelerating. Not sure what kind of interface you'd use to tell it that's what you wanted it to do though. |
07-22-2009, 09:43 AM | #13 | |
Moderator
7509
Rep 19,370
One thing I forgot to add to my last post though, is that, I suppose you could trick it by gunning the gas past the detent, waiting for the multi-gear downshift, and letting off the gas immediately and hitting the brake. But this seems dangerous, convoluted, and just not really a good idea overall. |
07-22-2009, 10:06 AM | #14 | ||
Rep 4,381
07-22-2009, 10:09 AM | #15 | ||
Rep 1,172
07-22-2009, 10:27 AM | #16 | ||
Moderator
7509
Rep 19,370
Actually that just made me wonder about something I've never tried before. I wonder what happens if you use the multi-stage downshift accerleration function (the one discussed above, using the throttle detent) at a very low speed. Will it actually drop you into first gear or will it only go to second? I have never even thought to try this on a street where I'd be moving slow enough for first gear to be available so I don't know. I'll have to try it out later. Quote:
07-22-2009, 07:55 PM | #19 |
Rep 10,407
What most are saying is correct. I'll add/summarize:
1. While in auto mode a large and fast throttle depression will grab multiple gears automatically, skipping the in between gears. S5 does this with less throttle input than S2 and similarly across the Drivelogic modes. 2. While in auto modes a full depression of the pedal will indeed give you a "maximum" downshift to the gear that provides the best acceleration. Again the intermediate gears are always skipped. I'm fairly sure you can't get a 7->3 downshift or 7->2 in S1 mode. It will only shift a couple gears down. All the other modes will provide a maximum downshift. The shifts for either of these scnarios are fast but not nearly as fast as a single gear auto or manual downshift. 3. While in manual mode you have to click the paddles very very quickly to actually skip an intermediate gear. I know you can skip one gear but not sure if you can skip 2, say 7->4. 4. While in manual mode if the go quickly to WOT and hold the downshift paddle you activate the kick down mode which just like #2 above will give you a fast and maximum downshift remaining in manual mode the whole time. This is really fun. Just as a note whether in auto or manual modes upshifts NEVER skip gears. The ability to skip gears is one characteristic that makes the DCT absolutely not a sequential.
07-23-2009, 03:06 AM | #20 | |
Rep 4,381
07-23-2009, 03:29 AM | #21 |
Rep 1,996
So SenorFunky - are you saying that you went straight from 7th to 2nd?
________________
My ///M is in my garage .... and it is a beast! 2010 E92 M3 Space Grey | Fully Loaded 1996 E36 M3 Dakar Yellow - SOLD 2004 Honda Accord Euro - SOLD |
07-23-2009, 03:52 AM | #22 | |
Rep 4,381
Its interesting from a technical point of view but not something that you are going to do in day to day driving. |
