05-08-2014, 09:46 PM | #1 |
DSC Off!
304
Rep 718
Any love for MCS?
I'm interested in any feedback for MCS single adjustables for street and monthly track days for my daily driver. I've searched and I don't see much on the forum. I'm looking at 450/900 spring rates.
Thanks folks. |
05-09-2014, 09:26 AM | #2 |
Rep 109
I suppose my feedback would be why would buy MCS singles when you can get Ohlins road and track for the same price? Also, I think you will be giving up grip at those spring rates particularly on corner exit and especially over bumps. If you are looking to firm up response then get a larger front anti-roll bar.
05-09-2014, 09:47 AM | #3 |
Rep 5,484
Currently have about 25000 street miles and tons of competition events on my MCS double remotes. Would buy again. Search for more info
05-09-2014, 10:25 AM | #4 | |
DSC Off!
304
Rep 718
I appreciate the feedback! |
05-09-2014, 10:57 AM | #5 |
Rep 5,506
The Ohlins "Road and Track" are track ready and still comfortable to drive every day on the street. Ohlins shocks are used in all forms of competition and OEM on Lamborghini, Pagani and other high performance cars. If you are looking for a great package, this is it. They also have the TTX which is designed for competition racing use.
Auto Detailing Enthusiast!
05-09-2014, 12:25 PM | #6 |
Rep 109
The opinion of Ohlins being more street oriented is the softer spring rate with the dampers valved around that spring rate. MCS states they offer a wider range of adjustment with the idea that they can be used on a wider range of spring rates but I would argue that is a compromise and makes them more of a generic damper vs. the Ohlins which are designed for the specific application.
05-09-2014, 01:18 PM | #7 |
Rep 1,711
OP, there are two members on this forum, i forgot their screen names, they posted very fast lap times at WGI with MCS single adjustables. On the other hand, Ohlins R&T get exellent reviews by owners. We just recently installed this system on my m3, i have not tested it on the track yet, but from what i feel so far, the ride is better than stock EDC, and car feels very stable at high speed corners with some body roll. But that could be attributed to the soft settings that i chose for street driving. Will come back with my review after i hit WGI soon.
05-09-2014, 04:16 PM | #8 | |
Rep 5,484
There is also no way to know from ad materials which one has the better damping curves, or which one maintains the integrity of te curve throughout its adjustment range. Shock dyno is the only way to know that. Rebound-only MCS could have less range for all we know, or be super linear, and vice versa
05-09-2014, 04:42 PM | #9 | ||
Rep 5,484
I recommend calling Lex Carson at MCS he may talk you out of buying something from him, or talk you into something different, very knowledgeable and not a salesman.
05-09-2014, 05:55 PM | #10 |
Rep 1,805
the ohlins R/T are too soft for the serious track rat. drove 2 cars with them, and one owner changed them after. Maybe if you can get them re valved for higher rates they would do better.
17' M2 DCT - KW CS - Re71r - Carbotech
BW C13 - 1:57:2 ACS - 1:49:6 WSIR - 1:30:6 |
05-10-2014, 10:04 PM | #11 |
DSC Off!
304
Rep 718
Seems like Richbot is the only one with much knowledge and feedback about MCS - I will call Lex, thanks. This will continue to be my DD for some time.
I hear more love for Ohlins, but I would like more info about MCS. Any reason to think that MCS is not as good (performance and quality) as Ohlins? |
daijc32.50 |
05-12-2014, 06:09 AM | #12 |
Rep 109
While I agree with much of what Richbot is saying I do not agree with the point on dismissing application specific as being irrelevant. Ohlins are digressive and from the posted force curves I have seen, MCS are as well. If both their force curves were linear than I would somewhat agree more adjustment is better but they aren't, they're digressive, and the shape of the curve is much of what matters. And when you are talking single adjustables it really matters what compression looks like relative to rebound as you twist your one adjustment knob. Ultimately you want a damper to be valved for the spring that is on it and the chassis they are mounted to. I would quite like to see both shock dyno plots posted up for a true comparison.
05-12-2014, 09:35 AM | #13 |
Rep 5,484
Sure but so long as one or two of the clicks on the range are optimal for most conditions the car will see or compete in, you are better served by a damper with a wider adjustment range. Digressive doesn't mean the knee lands the damping in the same place after the ramp. It's just a fancy way of saying the slope of the curve becomes sharply less steep at some point. A Digressive damper with a wider adjustment range will still be able to provide more damping force if that's where the range is bigger. And more damping force means more dampi force. Personally id rather have more tuning options than less, especially when you consider that a stiffer damper can take the place of a spring change for fine adjustments to balance, and takes 30 seconds rather than 30+ minutes for a spring change at one end or 2-3 minutes for a bar change
And glad we are in agreement that a dyno is the only way to know what's going on. Suspension tuners have been talking about matching components for years it's the number one marketing slogan "specifically tuned for your car" often meaning "we figured out the spring/damping rates it runs from the factory and didn't change it much!" Without a dyno showing how the damper behaves not only at the "default" setting but at each point in the range of adjustment, all we have to rely on is the assometer
05-12-2014, 10:29 AM | #14 |
11817
Rep 23,187
I have mcs singles on my e46 and think they are great, my spring rates won't help you as wrong car. It was my understanding at time of purchase that the mcs is more geared towards a stiffer spring track set up and have great customer service as well.
05-13-2014, 04:56 PM | #16 |
Rep 1,424
I have one of the first triple adj. MCS for an E46 M3, have driven the Miata on track used to develop the singles, have two friend with doubles (one on a 911 GT3 another on an E92 M3), and then there is 1moremod with singles……I guess I will call him a friend The MCS singles are spec for the new spec E46 class. MCS is also used in ST and GS Grand AM racing. Considering the singles are used in spec E46 I am sure they will be more than enough for HPDE. As far as I understand the quality of the singles is still top notch…….you just don’t get the extra adjustment. They are the top of my list and am considering them for my E92 M3 grocery getter
Spring rates? You will have to describe your driving expectations, style, experience, etc to an expert. Call Eddie at AR Auto Service 503-697-3311 He has set up all the above mentioned cars and more with MCS. All cars are very fast. |
05-13-2014, 05:34 PM | #17 |
Rep 542
Much love... Had the singles on my SCCA FR-S. Quality is fantastic & excellent support.
Would definitely do them again--anybody have a used set for sale? lol
* '11 E71 X6 M MCB
* '16 Z51 M7 C7 Corvette--SCCA Solo/DE Weapon * '90 Corvette ZR-1 (Fast) |
05-13-2014, 05:42 PM | #18 |
Rep 1,424
05-13-2014, 08:23 PM | #19 |
Rep 8,075
Drives: 11 E90 M3 Individual
WTF does track ready mean? That means nothing. What's suitable for a track only car? Depends. I like my TC Kline x2s on my E46...I'm going to keep running my TC Kline coilovers which are track ready in my opinion. I have no races to win and they make me happy.
Your main consideration is you'd like to run R-Comps or stickier tires in the future. Probably won't run full aero or need to win a race. I'd go with a coilover that has a well established acceptably performing spring rate for performance and comfort. What you probably do NOT want is to have to fiddle around with spring rates. Quite frankly, the difference in the HPDE world between Ohlins R&T and MCS is all in the driver. You can debate which one is more track oriented until this thread is 1,000,000 pages long. You want to put the coilovers on and then drive with a smile on your face. I ended up with the TC Kline's on my E46 because of the whole "the best spring rate depends on..." with every other coilover I asked other vendors about. Didn't want to waste my time and money trying to figure it all out. TC Kline did that work for me. I got my TC Kline's made one rebound adjustment. Haven't touched it 2.5 years later, still catch people in the corners. That makes it a great coilover. Nowadays there is more and more data for the MCS and JRZs. Just a thought.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue Last edited by bigjae1976; 05-13-2014 at 08:29 PM.. |
05-13-2014, 11:56 PM | #20 | |
11817
Rep 23,187
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
05-14-2014, 12:56 AM | #21 | |
Rep 1,424
05-14-2014, 08:30 AM | #22 |
11817
Rep 23,187
I think that also, although I sometimes wonder if I should have gotten doubles. For now the singles are great. I adjust one click softer for pacific and that's all I have to do, simple. I think too many variables would just confuse me, I like to show up and drive not sort out problems.
