01-21-2014, 06:09 PM | #1 |
Rep 698
Help me with my first code please 2b42
code details
misfire with emissions deterioration cyl 1/ engine misfire with emissions deterioration cyl 1 code 2b42 I get an occasional hesitation, like a misfire. ordered new plugs, you guys think i need a new coil? i was going to get in there and switch coils to see if it follows. any other help is appreciated.
2018 F80 ZCP
01-21-2014, 06:13 PM | #2 |
Rep 219
I dont know tbh but looking at the sticky above:
2B41 - P0300 (one less) http://www.m3post.com/forums/showpos...8&postcount=29 2B41 - P0300 Information saved in DME Fault code 2B41 - P0300 Fault text Misfire with cutout, several cylinders Fault description Random/Multiple Cylinder Misfire Detected Condition for fault identification Test condition: Miss capable of damaging cat on multiple cylinders Terminal condition: Terminal 15 Voltage condition: none Condition for fault memory entry Varies according to load and rpm Action in service Note selective logged error codes related to individual cylinders Fault effect and breakdown warning CC message Engine speed limited Reduced power MIL after engine runs 2x Rough idle Driver information Warning light: MIL, EML, CC message, backup program Service instruction None |
01-21-2014, 06:46 PM | #4 |
Rep 219
ok perhaps attempt2 simple google:
2B42 Combustion misfire with emissions deterioration cyl 1 if its just 1 cylinder could be spark, if multiple could be ICV (inlet control valve). but ill let the more experienced members confirm/deny. |
01-21-2014, 06:48 PM | #6 | ||||||||||||||||||||||||||||||||||||||
Rep 1,947
2B42 - P0301, Post-33
It looks like P0301 maps to multiple BMW codes. That makes sense because I would expect BMW codes to be more specific than a generic "misfire cylinder 1" P0301 error.
01-21-2014, 09:40 PM | #8 | |
Rep 7,544
01-22-2014, 05:07 AM | #9 |
Rep 698
Okay so i moved the coil and also inspected the spark plug. i really dont know what im looking at anyway lol. So i turned the car and and checked for any codes and nothing was present
When i removed the coil it was on there tight and the spark plug also, so there wasent anything loose that i could see. im going to assume the coil is going bad but why would it work in anther port....... anyway im going to change all the plugs and replace that coil. Anyway lets see if anything comes back I should have added that no codes came up on the car itself. i ran the BMWHAT APP with the bluetooth scanner and it found it. was also able to code the car. thing is awesome
2018 F80 ZCP
01-23-2014, 03:13 AM | #10 |
Rep 698
drove around all day with no codes or hesitations/misfires. im going to go ahead and change the plugs and that one coil anyway. So we now know that code is either a coil or plug and nothing else.
2018 F80 ZCP
01-23-2014, 03:49 AM | #11 |
Rep 564
See this thread http://www.m3post.com/forums/showthr...=ignition+coil.
Just do the plugs, I wouldn't bother with the coil as it should throw its own specific code - at least that was the case for me when coil #8 went and I used the above thread as reference. |
01-23-2014, 06:55 AM | #12 | |
Rep 698
2018 F80 ZCP
01-24-2014, 08:57 AM | #13 |
Rep 564
01-24-2014, 12:20 PM | #14 |
Rep 698
So all my parts came in and for some reason i decide to check the glove compartment and i find all the service history........
So look what i find.... my code said cyl. 1 misfire because the dealer took it out of 2 and put it in one to see if the problem followed hahahhaah. so it turned out to be a failing coil. All the spark plugs were just replaced. Spark plugs will go for sale lol. can belive the lazy dealer didnt just change that coil.....
2018 F80 ZCP
01-25-2014, 09:36 AM | #15 |
Rep 3,456
Drives: Harrop E90 M3
Apparently the fault never returned after they replaced the spark plugs and swapped them at the same time. The customer never brought the car back for the warning, and them appears to have sold it. Unless you just don't remember having the issue with your own car, but that doesn't seem to be the case. Ironically this appears to be the same diagnostic path you were going to take here. Speaking of lazy, who isn't familiar with their own service history?
01-26-2014, 06:18 AM | #16 | |
Rep 698
2018 F80 ZCP
