09-17-2010, 10:47 PM | #1 |
Rep 38
Cold Start Idle Stumble
During the cold start cycle; the first 10-20 seconds after the ignition button is pressed, the rpms are dropping lower than before.
On a few occasions there was a slight stumble, one time in particular the engine felt as though it was going to die.. (The car is routinely garaged, driven daily, and on this occasion the dash temperature read 72F). This phenomenon did not occur until the engine had approximately 20K miles. Before that the start up was smooth, going through the various rpm cycles until it settles in to a stable speed after ~20-30 seconds. I mentioned this to the dealer and the reply was that these engines do not get hot enough during routine use. Yes, but it did not happen when the car was new, nor did it occur on days when the ambient temperature was down in the 30s... Given all that can, and unfortunately does, happen this is minor unless it progresses. When I drove a vintage 914-6 with triple Webers, I expected some cold start "personality" but having this with the M3 seems out of character. Anyone else experience this or have feedback from the dealer? TIA |
09-17-2010, 10:48 PM | #2 |
Rep 2,736
Drives: 2008 E92 ///M3 Alpine White
Idle control valve?
09-18-2010, 02:37 PM | #3 |
Rep 5,012
Yep, your idle control valve is going out buddy. You're going to be greeted by the 'christmas lights' pretty soon, I'm afraid . When you do, you can usually get rid of them a couple of times by restarting the engine, but will be permanent after that. Apparently for us '08 owners is not a matter of IF we're going to have a problem with the stupid idle valve, but WHEN. Just hope mine acts up within warranty, which I'm starting to doubt as I only put about 4K miles a year at best. Good luck man.
09-20-2010, 10:43 PM | #4 | |
Rep 38
which only adds to my dealer frustration as they blew it off as temperature related despite a detailed description. In a perfect world I'd think they would at least note the issue and advise me to bring the car in when it fails or when impending failure is displayed via the "Christmas lights." Might be time to look into the other dealer in town. Thanks for the feedback. AC |
09-23-2010, 06:11 PM | #5 |
Rep 38
Additional clarification:
This low rpm / stumble only occurs during start up. When the ignition is pressed the rpms go up, then down, * then back up, finally settling down to normal idle speed after ~20-30 seconds. The rpm drop only occurs at the 1st start up cycle drop. After that the idle rpm remains stable. Given that, do you still suspect the idle valve? |
10-06-2010, 06:57 AM | #6 | |
Rep 1,179
After picking the car back up, the issue was fixed but now the engine makes a deep low frequency knocking / thumping noise that is linked to engine speed and not dependent on accessory loads. It's going back again to the dealer. |
10-18-2010, 06:12 AM | #7 | |
Rep 1,683
My M3 started to do exactly the same, and only after the car hasn't been used for a while. I hope it's not an expensive fix, as my car is out of warranty. Let me know what was wrong with your car in case you find out.
22 M4 Competition xdrive
19 M5 Competition sold 16 F-Type S AWD sold 11 Audi RS5 Misano Red--sold 08 E92 M3 Jerez Black 6MT--sold 08 E92 335i 6MT traded in for M3 |
10-18-2010, 07:11 AM | #8 |
Razzor
28
Rep 517
yea man my m3 did the same thing and i just got the car. its an 2011 e90 with 2000 miles on it lol...
2011 E90, 6 speed, technology package, black 220 rims , EDC, moon roof, matt black grills, matte side grills, 15% carbon tints, carbon fiber M pedals, ACS roof wing, IND painted reflectors, mfest black gloss m3badges, Mfest side window stickers, Tuner MS 15mm spacers, Carbon fiber M foot pedals, MS air filter, RPI air scoops, euro switch mod |
