11-26-2015, 05:02 PM | #1 |
Rep 35
Broken coil pack top
As you can see the back coil pack has a broken top so I can't grab it with my m division tool (other 7 were easy!)
So my question to you guys... How do I remove it without snapping it all to bits? It's a pain that the previous owner put that coil pack in the back too!!! ? |
11-26-2015, 08:58 PM | #3 |
Rep 35
So is that between the plastic of the coil pack and the metal of the engine block? Put it underneath, twist the driver then rotate the pack? Just keep doing slowly...
How robust are the packs? Anyone know rough cost of replacement? |
11-26-2015, 10:03 PM | #4 |
Bad Lieutenant
232
Rep 3,517
Use your fingers
11-26-2015, 10:10 PM | #5 | |
Rep 35
Success!! I managed to get it out easily enough, I used a screw driver to lever against the cam cover and it came out easily enough. Pretty tough buggers and didn't need much force at all to remove. Picture shows where to lever, against raised portion near screw. |
