05-01-2018, 03:45 PM | #1 |
Rep 56
Error 2B0D - Already replaced ICV
Hey guys and gals -
Fighting an issue that i've been having for awhile - my car runs great as long as I don't move the car until its completed the cold-start, but if i pull it out of the garage before the cold-start cycle ends it will go into limp. It has never gone into limp mode on the road, just during the cold start. I've swapped the O2 sensors and ICV at this point. Cleared codes today and induced the issue and the only thing that came up was 2B0D which points to the ICV that was just replaced. Anyone else had this issue? Thanks in advance! Last edited by Watersedge1234; 05-01-2018 at 03:54 PM.. |
05-01-2018, 05:44 PM | #2 | |
Rep 98
05-01-2018, 07:18 PM | #3 |
Rep 56
05-11-2018, 08:42 PM | #4 |
Rep 56
Anddd I'm back. TAs did not fix the problem.
At this point I've replace the ICV, TAs, and O2 sensors were replaced 4000 miles ago. Plugs and coils were also replaced 4000 miles ago. Checked exhaust manifold to test pipes and everything's good and tight. Only code I'm getting is 2B0D, and only occurs if I move the car during the cold start cycle. The car never has issues after cold start if I let it idle and run its course. Not a big deal but obviously we all want our cars running 100%! Any ideas? Vacuum leak somewhere perhaps? Trying to wrap my head around it. Car idles smooth after cold start, and now starts up instantly (used to bog before I replaced the ICV). |
05-13-2018, 10:21 AM | #5 | |
Rep 564
2015 K46 S1KRR
2008 E90 M3 |
06-29-2018, 05:29 PM | #6 | |
Rep 56
Same error - 2B0D. Checked for exhaust leaks and everything seems tight. Anyone else had an issue like this before? It's not deal breaking but annoying nonetheless! |
08-11-2021, 09:40 AM | #8 |
Rep 147
+1
Looking for fix too. Thanks!
2011.5 IB E90 M3, 6MT, speed cloth, carbon trim, ZCP, shades, ipod, alarm, and bluetooth. No sunroof. No nav.
2004 Mystic Blue 330CI ZHP - Sold. |
08-11-2021, 10:37 AM | #9 |
Rep 586
Found another thread with same issue - guy stated it was the donut gaskets connecting the headers to his xpipe. Going to change that
* 2011 M3 DCT * Built 4.4L Stroker * Gintani supercharger * Brembo GT * BBS FI * OHLINS * Nardo Grey *
08-11-2021, 12:31 PM | #10 | |
Rep 147
08-15-2021, 07:41 PM | #11 | ||
Rep 586
spammysammich1604.50 |
04-05-2022, 07:00 PM | #14 |
Rep 31
Update on my side: So, I was suffering the same codes. Changing that ICV was a pita (I yelled many German profanities). I replaced both the ICV/hose and the fuel tank breather valve (some other hoses while I was in there, and even broke the crank-case breather hose connector that connects to the front of the bottom of the intake plenum (so much rage that day), but I bandaided that for now (with some clever trick). I'm not getting any of the code(s) anymore. I'm planning on bring the car into the shop (waiting for the new lift to come in) to replace that Crank breather hose (F that), and do a cooling system refresh while it's in. Happy to answer any questions after doing that job (pita).
I checked my exhaust donuts, they were fine btw for me. My codes below. Thermostat may be due to a sticky thermostat (going to refresh the cooling system either way). 2B0D ICV is no longer present after probably 10 drives of varying length (after changing the ICV/hose, and for good measure, the fuel tanke breather valve). //////////////////////////////////////////////////////////////////// // BMW Trouble Code list // // ECU Type : Siemens DME MSS60 // // 1) 2B59 Coolant thermostat monitor // 2) 2B0D Idling speed control valve monitor bank 1 // 3) 2B57 Motor emergency programm activated //////////////////////////////////////////////////////////////////// Last edited by TheTrackDude; 04-05-2022 at 07:21 PM.. |
04-25-2022, 05:30 PM | #15 | |
Boost
1355
Rep 3,695
Drives: 135i M-Sport
Did you figure out the culprit? I'm running into this same issue after installing new TAs, 02 sensors and X-Pipe - threw in new header donut gaskets and I'm still getting the 2B0D code, the car ran great before installing these parts =( |
04-25-2022, 05:57 PM | #16 | |
Rep 31
My exhaust donuts were fine, not releated at all in my case. Sadly, in the final steps, my 1.5 year old repaired footwell module crapped out. So I went for a new retail unit this time (le sigh, this car, I swear...) |
04-26-2022, 12:58 PM | #17 | ||
Boost
1355
Rep 3,695
Think I'll replace the ICV + other hoses/valves anyways just to be safe with 90k miles and unknown maintenance history.
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
03-13-2024, 09:41 PM | #18 |
Rep 4
Restarting this thread, I’ve got the same issue as Watersedge, 2B0D only triggers when moving the car on cold cold start. I can clear it and drive no issues, I’ve cleaned the idle control valve and have looked into the brake pressure sensor but haven’t installed yet. Could this be my ICV electronics or something more simple?
03-18-2024, 08:26 PM | #19 | |
Rep 1,405
Do you go into the limp mode? What lights do you see on the dashboard? Have checked harness connection going to ICV? Make sure it's clean and tight. During the "warm up cycle" the PCM does some specific things that may be whats going on with your car. |
03-20-2024, 11:08 AM | #20 | |
Rep 4
04-09-2024, 01:25 AM | #21 | |
Rep 1
