12-07-2013, 02:21 AM | #1 |
Rep 421
S65 engine weight - and some surprises!
BMW claimed the S65 weighed 450 lbs when they introduced it. That seemed pretty light to me but then I started looking at some other normally aspirated V8s:
(0) BMW S65, 4.0 liter, 414hp, 295 lb-ft, 450 lbs (1) Coyote, 5.0 liter, 412hp, 390 lb-ft, 444 lbs (2) GM LS3, 6.2 liter, 436hp, 430 lb-ft, 415 lbs (3) GM LS7, 7.0 liter, 505hp, 470 lb-ft, 440 lbs I was shocked to find a 7 liter LS7 weighs less than the S65. |
12-07-2013, 02:26 AM | #4 |
Rep 421
12-07-2013, 02:29 AM | #5 |
Rep 3,934
SYT_Shadow11490.00 Assimilator1593.00 |
12-07-2013, 02:32 AM | #6 |
Rep 101
Keep in mind that the architecture of the S65 and the small block Chevys are completely different. S65 is DOHC, while the Chevy engines are just single cam OHV.
The additional cams and valvetrain of the S65 adds a lot of weight. The 5.0L coyote engine is more similar to the S65 in this regard, which is probably a good reason why it weighs similarly. |
12-07-2013, 09:19 AM | #7 | |
Rep 4,033
16 F82 M4 DCT - ZCP - JB4 - 556WHP / 570WTQ
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH |
12-07-2013, 09:54 AM | #9 |
Rep 8,076
Drives: 11 E90 M3 Individual
Even more surprising, the S54B32 is heavier than the S65B40 by about 30 lbs IIRC.
Still mystifies me how an E9X M3 is 300lbs heavier than an E46.
2018 F30 320iX Melbourne Red
12-07-2013, 11:32 AM | #10 | |
Rep 658
The BOSS 302 has a 7,500rpm stock redline and has no problem at 8K (S65s seem to be fine at 8,750) -pretty close IMO. |
12-07-2013, 11:52 AM | #11 | |
Rep 421
But ultimately, with non-FI, it is quite hard to get much over 100% volumetric efficiency. With lots of R&D, some engines get slightly better but not much. The two highest rated engines using torque per displacement that I know of are the Porsche GT3 and the 458 and those cost major dough, in part because of large investments in the drivetrains. That's why non-FI need either displacement or rpm to make big power. |
12-07-2013, 11:59 AM | #12 | |
Rep 658
The E46 has 269lb-ft out of a 3.2L |
12-07-2013, 12:16 PM | #13 | |
Id rather be boating...
67
Rep 1,097
I expect you to come back with some S54 specs next, but 7900 redline is not an 8750 redline. The S65 revs over 10% higher than the S54. |
12-07-2013, 12:18 PM | #14 |
Rep 264
12-07-2013, 12:31 PM | #15 |
Stop the hate, get a V8
3850
Rep 8,625
It's also got more "stuff", like more sound deadening, better chassis rigidty, more safety items, etc. That stuff is heavy.
Past: 2011.5 M3 sedan ZCP |
12-07-2013, 01:17 PM | #17 | |
Rep 8,076
Just an observation rather than a complaint...more lightweight materials but heavier curb weight. The fact is the M3 is just about the lightest 4 seat sports sedan that you can ACTUALLY fit 4 adults in.
12-07-2013, 02:22 PM | #18 | |
Perception is King
131
Rep 1,703
The extra weight comes from our dual cam head vanos set up and that awesome oil pan/8 throttle intake set up.
Perception and Reality are Two totally different Things.
12-07-2013, 02:41 PM | #19 | |
Rep 421
Here is an exercise: divide the torque in ft-lb by the displacement in liters for your favorite engines. Most likely they all fall between 70 and 80. Some may get into the high 80s. It won't matter what engine you choose, as long as it is normally aspirated, you'll see between 70 and 88 or so. More efficient designs get higher numbers. But you won't find any engine over 90 lb-ft per liter no matter what you look at. Even NASCAR, F1, they all need to obey physical laws. The 2.4 liter Formula 1 V8s, for example, only produced something like 215 lb-ft of torque. Pat |
12-07-2013, 03:20 PM | #20 | |
Rep 2,400
Also safety has been enhanced significantly from E46 days, especially in the side impact, where the E46 was weakest. Safety was improved significantly in the E9x models, judging by crash test results. As you stated, E90 especially has more load carrying capability.
12-07-2013, 03:47 PM | #21 | |
Rep 5,483
12-07-2013, 04:02 PM | #22 |
Rep 3,934
yup thats what i am saying. high low end torque only helps with daily driving in the most part. if you launch the M3 propertly and or keep in its power band the car will keep up or beat V8 muscle cars
SYT_Shadow11490.00 |
