06-23-2019, 02:50 PM | #1 |
MCB
Rep 10
Driveline Thud
Newby here - I just got an e90 m3 with a DCT and about 60k miles. The car works perfectly when it is cold. When its been driven for a while there is a loud thud/clunk when starting off from a stop. It almost feels like the car is being rear ended. No cow bell noise like i've seen when searching the forum or any other symptoms.
Any idea what this could be? Thanks Matt |
06-23-2019, 03:57 PM | #2 |
Rep 457
The DCT is a somewhat clunky transmission coming from a stop, it seems that there is no avoiding it. That being said, it does get clunkier with component wear and age.
Check motor mounts, transmission mounts, the trans-driveshaft flex disk, check the driveshaft for excessive play, and the diff and mounts. Are shifts hard? On S4, almost all shifts are shock-free, with some having a bit of a jolt |
m3_obsession1.00 |
06-23-2019, 08:07 PM | #3 |
MCB
Rep 10
Is it normal that the car would start off when cold flawlessly and get worse when hot? I have not checked the motor mounts but maybe they are shot and are worse when the engine compartment gets hot.
The transmission mounts look good, there is minor weeping around the passenger side of the transmission but not at all wet. The trans-driveshaft disk looks to be in perfect condition and the diff seems to have an appropriate level of backlash, the mounts look ok, and the subframe is bolted up tight. on S4 the shifts are firm but I would consider them shock free, with no abnormal noises. |
