      06-14-2019, 08:42 AM   #1
rmeitz167
bmw tech
rmeitz167's Avatar
473
Drives: g80 m3
Question for vf and ess supercharger owners
How is the inlet to your idle air control valve ran and do you have pictures? Does it go to the intake pre charger or is it going to the intake manifold? My gpower is set up to the manifold, and was causing a fault. Im curious how the other kits are run
      06-25-2019, 03:55 AM   #2
KingofKingz
KingofKingz's Avatar
Germany
17
Drives: 2012 M3 ZCP
What faults was it causing?
      06-25-2019, 07:44 PM   #3
rmeitz167
bmw tech
rmeitz167's Avatar
473
Drives: g80 m3
2b0d, dme: idle actuator monitoring, bank 1. Fault has Been gone and hasnt returned since blocking off the port once hooked to the inlet to the idle control valve. Which has a filter on it currently. However gpower insists they use that as a 9th throttle body sort of and ill be losing boost. So im working on getting a reducer from them that used to come in the earlier kits they sold. At some point the previous owner lost that, and then had this issue.
      06-25-2019, 08:56 PM   #4
eatsleepboost
eatsleepboost's Avatar
420
Drives: Evo
This thread may be of some help to you.
https://www.m3post.com/forums/showthread.php?t=842102
As for the ess kit hookup I can send you an email with the ess install instructions in PDF format that is very detailed with pictures and will show you everything. PM me your email address if you would like that.
      06-25-2019, 09:30 PM   #5
JsL
Drives: 2011 AW M3 ZCP
I have the VF instructions, you can pm me your email if you want that.
      06-26-2019, 03:26 AM   #6
KingofKingz
Germany
17
Drives: 2012 M3 ZCP
This reducer was removed in later software versions. Just ask gpower for a newer Software Version and everything is fine again. Do not mess around with those reducers.
2012 M3 ZCP | GTS | PP | Akra | SKIICS
      06-26-2019, 09:34 PM   #7
rmeitz167
bmw tech
rmeitz167's Avatar
473
Drives: g80 m3
Yup, and they want $1000 for an update. Im planning to custom tune the car anyway, just want things to be correct before i do.
