05-30-2019, 10:38 AM | #1 |
Rep 114
Couldn't shift into any gear.
So I had a weird issue this morning. Car was fine yesterday sat all night. Went to leave for work this morning and pushed clutch in and car started fine. I could not get the stick into reverse or any other gear for that matter. It was like the gate was not opening for me to push in the stick. If i pushed firmly against it the car would move slowly. I turned off the car and while off I could get into all gears and reverse just fine. Started it back up and still could not get the stick engaged.
Finally I started the car in gear and the car lurched forward. Thankfully I had the ebrake on and it slowed it enough for me to react and hit the brake. After this everything worked as normal. Made it to work just fine no issues. Going to check fluids again later. But pedal and everything seemed normal. Anyone ever experience something like this? Car has 57K miles, trans fluid replaced within the past year. |
05-30-2019, 08:53 PM | #2 |
Rep 399
Sounds like although your clutch pedal is depressed all the way, the clutch itself has not disengaged. Could be air in the clutch hydraulics or issue with clutch master or slave cylinder.
-David
05-30-2019, 10:44 PM | #4 |
Rep 2,747
Sounds like clutch is gone buddy, out of interest what year is your car, any mods? I have an 08 with 82k miles, I've already got a new clutch for PM.
9ers
05-30-2019, 11:15 PM | #5 |
Rep 114
Well, everything worked as normal the rest of the day today. Ran a few errands after work. Started and shifted just fine. Weird. I have an autosolutions shift kit coming so I will check out both master and slave at install if all acts normal until then i guess.
05-31-2019, 04:46 AM | #6 |
Rep 979
This is the same thing that happened to me when I needed a new clutch. I was close to the same mileage.
05-31-2019, 08:09 AM | #7 |
Rep 114
Not really what I want to hear lol. I am hoping it's something smaller like the slave cylinder but I guess we'll find out. Going to check it out this weekend see if there's any leaks, etc.
05-31-2019, 10:09 AM | #9 |
Rep 114
That's what I was thinking. Supercharger has only been on for about 10k miles and those miles have been over a 2year period, never tracked or anything. I guess the car is 10 years old, might be age related... Master and salve cylinders are cheap enough, i'll start there for now.
05-31-2019, 11:12 AM | #10 |
Rep 2,747
MVY you're supercharged too right? What kind of clutch did you put in it?
9ers
05-31-2019, 11:28 AM | #11 |
Rep 114
05-31-2019, 11:41 AM | #12 |
Rep 2,747
I have a SPEC clutch to put on my car for supercharger... it's a heavy sob though with a steel flywheel
9ers
05-31-2019, 01:33 PM | #13 |
Rep 399
Don't listen to these guys saying your clutch is done... yet. You might just need to top off your brake fluid. The fluid pickup for the clutch is near the very top of the brake fluid reservoir.
-David
05-31-2019, 07:20 PM | #14 |
Rep 979
I went stock. I think it was a Luk clutch and a BMW flywheel. In the 2008 you had to upgrade to the 09 flywheel which made it even more expensive. OP is lucky hes an 09 as he wont have that extra cost.
05-31-2019, 07:22 PM | #15 |
Rep 979
True, but how many owners on this car before the OP? On mine I had 2 owners and one of them must have learned how to drive stick on the damn thing ;-).
06-03-2019, 02:30 PM | #16 |
Rep 548
Drives: 2011 E90 M3 ZCP
Any updates here? This problem is IDENTICAL to what happened to me yesterday. Thank god I was home so my car is stuck in my driveway! ;-)
This problem feels like a hydraulic issue. Most cars would have the clutch pedal sink to the floor but I believe due to the springs we have on the pedals, that's why it's returning back to normal (that's my theory at least). I won't have time to check this until tomorrow so I'll try and bleed first and see if that resolves it. Hopefully it's as simple as that! |
06-03-2019, 04:02 PM | #17 |
Rep 548
Thought I would add this, check this out. Very weird!
https://www.m3post.com/forums/showth...9#post24654629 |
06-03-2019, 06:06 PM | #18 | |
Rep 114
06-04-2019, 06:30 AM | #19 | |
Rep 548
I tried to push it while in gear (clutch down) and no dice. I thought that might be enough to free it up but apparently not. |
06-04-2019, 10:49 AM | #20 | |
Rep 114
06-12-2019, 02:36 PM | #21 |
Rep 548
Just an update here. I closed my eyes and started the car in gear with the clutch down. Relatively no drama, and everything was back to normal. The car shook ever so slightly and then all was well in the world. Very odd but I can only attribute this to water getting onto the clutch/flywheel somehow and it slightly rusting it together (similar to brake pads and rotors when you wash your car).
06-26-2019, 11:20 AM | #22 | |
Rep 114
