      08-21-2017, 06:27 PM   #1
MatrixRSi
Drives: 2008 Jerez Black M3
Intake Temperature Sensor Connectors
Ask: Can someone please unplug their air intake temperature sensor and tell me if their plug has two gold connectors (the plug, not the sensor itself).
I replaced the throttle body actuator last weekend but I got a new code from Carly: air intake temperature sensor. It wasn't a problem before. When I was putting everything back together I felt like I may have pulled the connector and maybe one of the wires pulled out of the connector. Why do I think this?
The actual sensor has 2 pins and my plug only has one gold connector in it.
- I have pulled away the plastic cover from the plug and there is one wire (greenish/red)
- I have tested the connection in the one side with a circuit tester and it is getting power
- I cleaned the sensor lightly with alcohol
Maybe I just need a new sensor but if I pulled out the wire from the plug that would be a real headache. Please let me know if yours only has one.
      08-22-2017, 08:38 AM   #2
deansbimmer
deansbimmer's Avatar
3751
Drives: 2011 E93 M3
1988 BMW M3  [0.00]
2013 BMW M3  [0.00]
2011 X5M  [0.00]
2011 BMW M3  [0.00]
Yes the IAT sensor wire has two conductors. The oil pressure switch just below it in the oil filter housing has one conductor and a similar connector. Is it possible that you accidentally mixed up the two?
If you pulled out one of the wires from the IAT connector by accident, it should be a short process of relocating it from the area... If it damaged the housing or wires, BMW sells a replacement pigtail (PN 12517841385) since technicians commonly damage this when removing the plenum.
Patrón544.50
askme82.00
      08-22-2017, 10:35 AM   #3
MatrixRSi
Many thanks for the detailed reply!
      08-25-2017, 12:37 PM   #4
B73M
B73M's Avatar
15
Hi Matrix, don't mind can you tell me how do you remove the sensor out? I can't seems to remove it despite being able to turn clockwise and anti clockwise, but I still can't plug it out.
Thanks.
      07-06-2019, 04:58 PM   #5
richie324
Drives: 2008 E90 M3
I cannot find the connector for my intake temp sensor. Can someone show me where the connector comes from and where it is?
