12-01-2014, 04:28 PM | #1 |
Rep 225
Drives: 2011 Space Grey E90 M3 DCT ZCP
Brake Pad Advice
Might be doing my first track day within the next month or two so I was pondering the whole brake situation since I've been reading it's the only "weakpoint" on the car.
For starters... the car is a bone stock E90 ZCP on PZero's. I don't have any track experience but I used to autocross often but I haven't in a while. Not to mention that was in an S2000. Bottom line is I don't expect to out drive what the car is capable of any time soon. The car only has about 28k miles so the stock brakes are in good shape and I'm still in the BMW maintenance and warranty period. I think my rears are due to be replaced (based on time) just prior to when I would likely do a track day. Brake fluid will be flushed and replaced with ATE 200 prior. My question is whether or not I should change from the OEM pads to start. My options I guess are: 1. Run on OEM pads + fluid (at least for first track day) 2. Upgrade to something like Pagid RS19 (RS19 seems to be the forum favorite). Also, if I do change pads I'm assuming I'd have to get the rotors turned/resurfaced prior to that or can the aftermarket pads be used on the current rotors with just the bedding process and just pad swap between street and track?
Marc
2011 Space Grey Metallic E90 M3 DCT ZCP Last edited by M.A.R.C.; 12-01-2014 at 05:27 PM.. |
12-01-2014, 05:40 PM | #3 |
Rep 5,506
OEM pads can hold up depending on how hard you are on them. The stock brake fluid definitely will not. I would do a brake fluid flush before going. ATE 200 is not good enough. It will not withstand the heat.
Auto Detailing Enthusiast!
12-01-2014, 05:41 PM | #4 |
Rep 225
yeah fluid is definitely planned. was just curious on the pads holding up.
Marc
2011 Space Grey Metallic E90 M3 DCT ZCP |
12-01-2014, 06:24 PM | #5 | |
Rep 300
Seems that everyone I know...including novice drivers...develop "pad deposits" after one day with a shuddering steering wheel under brake. I would recommend switching out. |
12-01-2014, 06:25 PM | #6 |
11817
Rep 23,187
+1. Rotor change isn't needed just bed them properly.
12-01-2014, 06:28 PM | #8 |
Rep 225
that's true. I have a friend with a F80 335i that tracks on all stock components and his brakes seems to hold up fine. another thing i'm considering is since i'm still under warranty/maintenance so I might try it out on stocks first
Marc
12-01-2014, 06:29 PM | #9 |
Rep 5,506
I drove on the track with stock pads. I wasn't very hard on them knowing they were stock pads. I'd do 4-5 laps and pull out early when it was fading. (about 1/2 of a 20 min session) Then do a few cool down laps driving normally around the paddock area before parking. Seemed to be ok.
12-01-2014, 07:58 PM | #11 | |
Rep 356
12-01-2014, 08:05 PM | #12 |
11817
Rep 23,187
Depends how bad they are. Dealer told me I had the worst warped rotors they ever saw, didn't believe them because knew it was deposits and after switching to track pads they were fine. May take longer than couple hundred but will come off eventually.
12-01-2014, 08:48 PM | #13 |
Rep 969
When it comes to track days, get a dedicated set of pads and preferably rotors as early as possible. Changing pads and rotors can be done very quickly and insures you/your car will stand what you are about to throw at it. Stock pads are great for street or autocross but really are prone to brake fade pretty quickly if you push it at all. Nothing worse than finding out 2/3's through 25 minute session you have to come off because they are getting questionable. Dedicated pads are noisy, abrasive and can leave ridiculous deposits which need to be removed ASAP, but they do stop you when you are going fast.
Sold 2011.5 E92 M3 ZCP.
12-01-2014, 09:19 PM | #14 | |
11817
Rep 23,187
12-01-2014, 09:51 PM | #16 |
11817
Rep 23,187
12-01-2014, 10:44 PM | #18 | |
Rep 4,488
Going to race pads right away can make it much harder to be smooth under braking at a stage in your driving where learning to be smooth will already be plenty challenging, and on stock tires your race pads will be able to overpower your tires easily, so you'll either have to get much better at threshold braking much faster or deal with the instability of earlier and more frequent ABS intrusions while trying to slow down and turn in, which is why I recommend only getting as much brake pad as your track and skill level requires. But yes, upgrade your fluid. I do some trackside garage work sometimes and fluid bleeds on cars driven by novices running stock fluid are by far the #1 job out there.
12-02-2014, 12:19 AM | #19 | ||
Rep 356
12-02-2014, 08:28 AM | #20 | |
11817
Rep 23,187
12-02-2014, 09:18 AM | #21 | |
Rep 633
Have fun but please dont use stock fluid on the track, I have had intermediate students freak due to pedal getting almost half way down. Stock pads some can wear it fine, others to the plate in a weekend. YMMV. Lutfy |
