      04-16-2015, 10:11 AM   #1
SloPoke
SloPoke's Avatar
Drives: 2010 135i
How to fix Mirror misalignment
So I had just picked up my new to me e92 and after a few days noticed that the mirrors did not align properly. Being anal about stuff like this, it bugged the hell out of me. I posted the question in the General forum and Malek came to the rescue. There seemed to be a ton of people who had this same issue, so I figured I would put this out in the DIY so others might stumble across it.
Originally Posted by Malek@MRF View Post
Mirror Re-Alignment Procedure:
  • Push folding mirror away from you all the way. As in push mirror toward front of car, do not fold in.
  • Push mirror folding button on drivers door.
  • Mirror will fold all the way inward, bind and then "pop".
  • Press mirror button once more to unfold mirror.
  • Mirror should be realigned.
Appreciate 6
      04-19-2015, 02:03 AM   #2
BzsBimmer
BzsBimmer's Avatar
3274
Drives: '23 G80 FO M3, M3 & MY Tezzy's
Just did this literally after reading this.
      05-09-2015, 05:46 PM   #3
mxa121
mxa121's Avatar
226
Drives: M
BOOM!
      05-10-2015, 08:32 AM   #4
e92m3_jesse
e92m3_jesse's Avatar
Drives: M3 E92
Made my day
Been bothering me for months but no more.
      05-30-2015, 01:48 PM   #5
bigfy39
Drives: e46 328ci
Anyone have the mirror misaligned the opposite direction from the OP's mirror? Couldnt get this to work backwards.
      05-30-2015, 09:07 PM   #6
BzsBimmer
BzsBimmer's Avatar
3274
Go through the same steps but when complete the mirror will lug back to find it's correct spot. Pull again on the mirror (it will not want to move so you need to force it somewhat) towards the window and then press the window button again. It will click and pop back in to position.
Mine did this when I reset and I thought I broke the damn thing. By pulling back towards the window and pressing the button, it chugged its way back.
      03-16-2016, 04:14 PM   #7
monterey
monterey's Avatar
339
Drives: 2008 M3
Can someone elaborate more on this procedure. it's not crystal clear to me.
A job is nothing but work.
      03-18-2016, 05:48 PM   #8
rvtrcr
Drives: '09 M3 Sedan
Unfortunately didn't work on mine. Both are misaligned and tried pushing them forward as well as back.
      03-20-2016, 09:08 PM   #9
BzsBimmer
BzsBimmer's Avatar
3274
Try doing it again?
      03-22-2016, 03:39 PM   #10
rvtrcr
I have, it's weird... just keep going back to the same place.
      04-28-2016, 02:21 PM   #11
gfisher99
Drives: '11 E92 M3, '18 M2, '22 X3M
Man, that grind and pop are scary, but it worked on my driver side. My passenger side is still slightly off. Might have improved by a mm or two though. Thanks for the info.
      04-28-2016, 05:34 PM   #12
Tewie
Tewie's Avatar
Drives: 2011 E92 ZCP Melbourne/FoxRed
      05-08-2016, 10:08 PM   #13
Nelson999
Nelson999's Avatar
21
Drives: Space Gray E92 M3
Wow, quick and easy, thanks!
      01-08-2018, 04:20 PM   #14
jeff_cookie
Drives: e90 m3
This kind of helped my passenger side but didn't help drivers side. Any other ideas?
      10-25-2018, 01:36 PM   #15
phantasticphan
phantasticphan's Avatar
Drives: e91 Touring, e92 M3
Just did mine and it worked for me...it was so annoying before when it wasn't aligned
      06-04-2019, 12:06 AM   #16
Lor443
Drives: 2010 M3
My mirror alignment was off so I followed the above and the alignment is fixed. However now when I push the button to fold my mirrors in or out the driver side does not fold. The mirror moves slightly like it's trying to fold but doesn't really go anywhere.
Thoughts?
      06-04-2019, 12:39 AM   #17
SAMM3Y
SAMM3Y's Avatar
3085
Drives: 2008 m3
Thoughts?
Try helping it when you push the button but your mechanism is probably worn excessively, if it was coded to fold when you lock your car it's probably worn out. It happened to mine, I took it apart it and found the plastic cam and bearing worn/broken and missing the stop and 180 degrees out. It isn't a serviceable part without replacing the mirror. Try manually folding it and pressing the button too. See if you can get it back into position.
9ers
Davisca4552207.50
      06-04-2019, 12:47 AM   #18
Lor443
Drives: 2010 M3
Hey Sammy,
Helping it does not change anything, it hasn't been coded. When folded the same thing happens it moves very little but not enough to even look like it went anywhere.
      06-04-2019, 01:16 AM   #19
SAMM3Y
SAMM3Y's Avatar
3085
Drives: 2008 m3
Hey Sammy,
Try following this service bulletin, it says it's for e9x with power folding mirrors
https://www.bimmerfest.com/forums/sh.../topics/704099
9ers
      06-04-2019, 05:04 PM   #20
Lor443
Drives: 2010 M3
Didn't work the mirror only moves slightly everytime I hit the button.
      08-01-2022, 11:11 AM   #21
x3sm
x3sm's Avatar
282
Drives: M3 E93 Porsche
Bumping old thread because of similar issues. I did the procedure, but my driver side mirror is lazy to close and cannot catch up to the passenger side. I wished someone made rebuilt kits for these.
M3 E93
PORSCHE MACAN S: SOLD
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      09-11-2022, 07:48 AM   #22
S65M3AL
Drives: 2014 F30435i, 2009 E92M3
Awesome, thanks! I just buy an 2009 M3 and noticed that both mirrors are misaligned. Will do this when I get it back form the shop.
