      02-04-2014, 01:57 PM   #1
4corners
4corners's Avatar
Drives: 2008 Jet Black M3 Coupe
? quick replace rotors?
Can I replace the rotors without removing the pads or calipers? I think if I tilt the disc it will clear the hub flange and come out of the caliper. Slide in new OEM disk with same pads.
Anyone know. ??
      02-04-2014, 02:06 PM   #2
Grail05
Putcha ang ganda...
Grail05's Avatar
Drives: 17 F82 M4
not sure if this is serious but to answer your question is NO.
it takes half an hour to removed the rear or front rotors.. i replaced my front and pads in 45 minutes. make sure you have all the proper tools and some extensions...
      02-04-2014, 02:09 PM   #3
K.M. Tim
K.M. Tim's Avatar
203
Drives: 2011 M3 ZCP 6MT
2011 M3  [2.00]
2012 BMW F30 w/ M S ...  [0.00]
Asking a question like that means you have never worked on rotors/brakes/calipers or you would know the answer is no. DIY- look it up then try. Its the only way to learn.
///MFlight Admin
      02-04-2014, 02:26 PM   #4
4corners
4corners's Avatar
I've done plenty of brake jobs and on this vehicle too. I have a set of used rotors w/25k to replace mine with 100000 miles. Pads are 75% remaining. You don't have to insult me to offer a comment.
      02-04-2014, 06:02 PM   #5
arter
collecting toys
arter's Avatar
41
Drives: M3 MCB
Front just unbolt the caliper and move it out of the way and you are good,
Rear you need to remove the caliper support bracket too to get them off.
Still a quick job.
2011 e92 M3 Monte Carlo Blue ESS 535 - gone but not forgotten
2015 cayman GTS - new toy
2006 SLK 55 AMG sold
      02-05-2014, 11:24 PM   #6
4corners
4corners's Avatar
I was able to get the right front rotor to slip out without removing the caliper. (just to see if it was possible). But I could not get the newer thicker one in so I removed the caliper. All done and much better than my old 100,000 mile rotors.
      04-10-2014, 06:38 PM   #7
kwike92
kwike92's Avatar
Drives: 2014 M5 CP
hm, I have never heard of removing a rotor without removing the caliper...
2014 M5 Comp Package.
      04-10-2014, 06:59 PM   #8
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
i thought that might be a possibility but i always had studs as well which means the rotor has to come straight out sliding the length of the stud, thats what she said.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
