08-03-2015, 09:50 PM | #1 |
EXC MIII
103
Rep 627
Drives: on the wrong side
Removing Betalink
So I want to remove the performance spoiler my dealer installed with Betalink. Is it even possible to remove this stuff without damaging the clear coat?
I found threads referencing the use of fishing wire and razor blades etc but not convinced as I didn't see evidence of any success with these methods. Anyone pulled this off or should I have just taped it on myself/factor the cost of a respray?
2011 E90 M3 ZCP: Harrop | Remus | Vorsteiner | Arkym | BMW Performance | UUC | Recaro etc
Check out my build: Limey's E90 | Daily Driver Evolved |
08-05-2015, 06:43 AM | #2 |
Rep 855
I replaced my performance spoiler by using a pressure washer. Its an electric 1600psi.
After cutting the wing off with the pressure washer, i got very close to the trunk and blasted the stuck on betalink. I got seriously close.. About an 1/8 inch (or closer) at a 45 degree angle! It did not come completely off but, it was perfectly smooth. In other words, there was a line like it was drawn on with a Sharpie marker. Since i was replacing the wing, i didn't need to worry about completely removing it. The line of remaining betalink was so thin that it may have been able to be removed with a heavy cut compound. Hope that helps (if you have a pressure washer)!
-- 08 JB e92 6MT ///M3 ESS VT2-625 --
08-24-2015, 01:34 PM | #4 |
Rep 855
Care to give your experience using a heat gun to remove betalink?
08-30-2015, 04:45 AM | #5 |
Rep 963
Here - I remembered reading this and found it for you
http://www.e90post.com/forums/showthread.php?t=169731 Others on cutters have reported fishing line works well Regards |
