08-13-2014, 01:50 PM | #1 |
Rep 542
DE setup (stock ZCP susp/camber plates/front bar/square) DD camber question, too
Getting my car prepped & starting this fall (needs to cool off!)...
I'm looking to run the setup in my title, for now. I believe the front bar will effectively stabilize the rear, so I can run a square tire setup with impunity lol. I'm thinking this setup should perform nicely. Thoughts? Bar suggestions? The car is my DD, and my main question/concern are the camber plates. Seeing that I'll be driving (and leaving my truck & trailer home), I'd like to adjust the plates when I get there, then return to street setting before I leave. Sounds simple enough, but how sensitive is the toe adjustment & will I throw it off completely, every time I adjust? I really would rather not have to do an alignment @ the shop after every event. What are those with camber plates doing as a solution? TIA, all...
* '11 E71 X6 M MCB
* '16 Z51 M7 C7 Corvette--SCCA Solo/DE Weapon * '90 Corvette ZR-1 (Fast) |
08-13-2014, 01:55 PM | #2 | |
Rep 6,734
Excerpt from a current thread in track section:
http://www.m3post.com/forums/showthread.php?t=1022360 Quote:
FWIW I'm running staggered wheels / tires and was actually experiencing over-steer on my last track day... but I had just added adjustable sways and ran with Euro MDM for the first time. The sway bars introduced another level of suspension tuning which is more than I honestly need...
'23 X7
08-13-2014, 01:58 PM | #3 |
Rep 6,734
FWIW - most camber plates increase ride height. I would recommend just buying KW Clubsports or one of the other great coilover systems available vs screwing around with your OEM suspension. You will inevitably want to make that upgrade if you track the car. You are kidding yourself if you don't believe that to be true...
'23 X7
08-13-2014, 02:08 PM | #4 |
Automobilist
395
Rep 2,632
You'll get a lot of different opinions on this. I am running Vorshlag camber plates with a compromised track/street setup -2.4 camber F, -1.9 R and 1/16 toe in all 4 corners. My shop advised against adjusting camber at the track as it with throw off the toe too much.
I've only had the car out for 1 track day since the install and the car felt good with less push than stock on certian turns I would nromally feel it. I still feel like I could use a little more camber up front as I was still getting some understeer, but I just adjusted my turn-in a bit. BTW my ride height didn't change. |
08-13-2014, 02:11 PM | #5 | |
Automobilist
395
Rep 2,632
08-13-2014, 02:14 PM | #6 |
Rep 6,734
'23 X7
08-13-2014, 02:41 PM | #7 |
Rep 542
Slicer--informative posts, as usual--thx.
I'd use GC plates. Super-high quality & non-lifting & a hat change away (when) the C/Os magically show up at my door... lol You mentioned primarily track-focused above, but it's the opposite--probably only 8-10 events/year of use. Thx to Esquire above, as well. Good stuff--keep it coming! |
08-13-2014, 03:15 PM | #8 |
Automobilist
395
Rep 2,632
08-13-2014, 03:21 PM | #9 | |
Rep 6,734
'23 X7
08-13-2014, 11:59 PM | #10 |
Rep 1,424
I would recommend you set the camber and leave it. My "street" camber is -2.2 in the front. This is as positive as I can go with GC camber plates and comp package. You might be able go to around -2.8 without too much inner tire wear. Just run front pressure up to ~38 cold on the street.
BTW KW club sports are fair to good with some limitations. There are better options. |
08-14-2014, 12:34 AM | #11 |
Rep 6,734
What are the limitations, what other options do you recommend(in the same price range), and why?
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 08-14-2014 at 12:44 AM.. |
08-14-2014, 11:33 AM | #12 | |
Rep 1,424
Then there is the front wheel/tire clearance that makes it difficult to run a square set up. The above car moved to MCS doubles in part to get passed these limitations. I would rather run a MCS single adj. than KW cs. You would have none of the above issues and a race quality product. If I was in the market I would also look into JRZ but my knowledge is limited with regards to their products. Disclaimer: I have the first MCS triples put out for an e46 m3. |
08-14-2014, 12:00 PM | #14 | |
Rep 6,734
I wouldn't say KW's are camber challenged. I'm getting -2.8 which is limited by the shock tower opening. I could get well into the -3.5 range (or more) if I dropped the top hat down to adjust. MCS single adjustable are still going to be more expensive than KW's (by the time you add in camber plates, spring perches, etc.). As far as tire clearance... I agree that is a PIA. I ended up solving that problem by swapping in 30mm shorter Eibach springs; problem solved but it cost an extra $200 to achieve. Lastly my experience on "race quality" dampers is that they need to be refirbished relatively often. Is that the case with the MCS? I'm not saying KW's are the best, but I am saying they are a very cost effective plug and play solution (all parts including camber plates included) that seems to be very durable. Well with the exception of the adjustable spring perch set screws which like to strip out... I would definitely run MCS and/or JRZ as I know they are great products. KW Clubsport 2-way's are just tough to beat in the $3k price point. I have the 3-way version which retails for $5600.... that put me into a higher price realm where JRZ and MCS plays. I have been happy with my suspension but would definitely be open to the other more race oriented options. That being said, I would also consider the KW competition products which are more directly comparable.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 08-15-2014 at 11:34 AM.. |
08-14-2014, 01:32 PM | #15 |
Rep 5,514
No, MCS dampers are very durable and do not need to be rebuilt frequently. Unlike Ohlins R&T dampers which do not contain any of their race damper internals and need to be rebuilt after only 15k street miles, MCS dampers will give you >> 15k street AND track miles. I'm running Ohlins R&T dampers on my Mini Cooper S and after only 10k street miles there was a significant drop off in performance. Sad.
08-14-2014, 03:12 PM | #16 |
Rep 5,484
My MCS remote doubles have nearly 30,000 street miles on them. No signs of any problems. Haven't had to change adjustments for street use etc. Hold nitrogen pressure very well too, I have yet to need to top one off.
08-14-2014, 03:56 PM | #17 | |
Rep 5,514
Another advantage to MCS dampers is you can upgrade a MCS 1-way internal-reservoir damper to a 2- or 3-way remote-reservoir damper. |
08-14-2014, 06:06 PM | #18 |
Rep 6,734
Really? That's awesome. I love when companies make their products upgradable.
'23 X7
08-15-2014, 09:16 AM | #19 |
Rep 5,514
Yep. They also give you full credit for the dampers you've already purchased so the price to upgrade is the difference between the price of the dampers you're upgrading to and the original price you paid for the current dampers.
08-15-2014, 10:24 AM | #20 |
Rep 5,484
Which is also a good deal for them because the price to upgrade in t&m is way lower the the cost delta. But nice they credit you I agree.
One more note on MCS. I bought these things 2.5 years ago and service after the sale is as good today as the day I bought them. The upside of a small nimble US company selling an expensive specialty product to a small and interconnected market. Downside is if they don't stick around you have very expensive custom stuff with no support from the OEM. But so far they seem to have staying power. Jrz and kW seem to have a little more provenance f that's important to you but the proof in the pudding is in the tasting and mines pretty tasty
08-15-2014, 12:04 PM | #21 |
Rep 1,424
I almost feel like I should shut up because everyone is doing such a great job of supporting MCS. But I have a few points that are also relevant:
MCS singles are the spec suspension for the new spec e46 racing class. IMSA has opened up and allowed MCS. I have heard that a large percentage are switching out their AST for MCS. I don’t know if this is just ST and GS or all classes. Like others I have had zero issues with my MCS triples (track only). But bottom line they perform! They allow you to do things others can't. |
08-15-2014, 12:07 PM | #22 |
Rep 1,424
Used for sale! That would be the ticket! I would gladly pay for new if my e92 m3 was my primary track car but for me it doesn't make much since to spend money on a second car.......but I would buy used!
