11-10-2014, 12:24 PM | #1 |
is fast cars
391
Rep 2,137
Thoughts on the E9x from a BMW Tech
From a post on Jalopnik's Car Buying (my responses in italics):
Your resident BMW wrench says this car isnt actually bad to own. Manual trans is solid, aside from leaks the DCT is solid, the body and suspension is solid. Only real issues on this car are an evaporator thats a seemingly 100% failure rate as they are made of thin aluminum and corrode, the odd broken valve spring in the engine but the most worrisome issue is bottom end problems. They have been known to chuck rods rather dramatically or have bearing wear. They actually have very thin and small bearings and seem to be an issue to be aware of. However it should be ok if you keep up on maintenance, don't beat on it or boost it (they dont like that, trust me i have half of a rod for a souvenir) I really appreciate your input! Mine is still on its original clutch after 70k miles (and I don't baby it) and I did get my evaporator replaced (under original warranty, thankfully). I'll be keeping an eye on the bearings with Blackstone reports. Of the bearing failure(s) you've seen, how many miles were on the engine, or was the failure related to a supercharger, poor warm-up discipline, or something? Definitely boosted. We've seen a lot of non boosted cars too so i think the thin bearings really can't handle the boost and that just speeds it along. Mileage? It varies, a lot. 30k was the lowest and that car had a blower, we also had a thrust bearing fail super early on a car but that was an anomaly as ive never seen another. I HIGHLY recommend oil analysis on this motor and the S85 V10. I also would do your oil changes 5-7k miles depending on use. It does seem to effect early cars more than late, but when they change bearings or make minor internal changes they never tell us. This wont effect every car but its something thats known to happen and should be taken care of. Its nowhere near as prevalent as say the IMS failure on Porsches, but just as pricey. Other than the odd motor mount and rotors that warp at the track its really a great car. I honestly think it will be the "E39 M5" of M3s. Last of the greats. Sure the new one is trick, but its the size of an old 6 series, and sounds like shit. Nothing sounds like that E9x's S65. Thanks for all the good info. I've been changing oil at 10k intervals (15 is insane), but I'll probably switch to half that or 7.5 on your recommendation. Some owners are swapping to Mobil1 0w30 (*edit - I meant 0w40...) - not sure of your thoughts on that. I'll probably also look into a preventative bearing swap at some point in the not-too-distant future. I love mine, and you're right, that sound... No need to worry about bearing swaps unless your oil analysis comes back with an issue, and by that time it could have more then just bearings as the material works its way into everything. The S85 was like this and they would show up with VANOS issues due to the bearing material damaging the VANOS pump and units. 0-30 is far too thin. That would do damage for sure. All our other cars run 5w30 so we have it on tap but BMW spec'd 10w60 for a reason. My guess is most owners that are switching would rather pay $8 a quart than $16 for the right oil. Our new cars for '14 have dropped into the 6-8k range for services. After years of us bitching about it damaging engines long term, eatting up seals, and causing issues with VANOS units and turbos seems like engineering finally beat out the bean counters and BMW figured it out. Thats a big expense if you figure now maintenance will DOUBLE the amount of oil changes for 4/50 but its less of a cost than the warranty claims and pissed off customers when there 7 year old 90k mile 550 needs a $8k reseal and valve guide seals..... or CPO pays for it... Great advice - thanks again. Last edited by davesaddiction; 11-10-2014 at 03:58 PM.. |
11-10-2014, 01:00 PM | #4 |
Rep 734
Is there anyone, anywhere who doesn't realize that adding a supercharger to ANY engine, especially adding 50% HP to an already high specific output engine is going to significantly reduce longevity?
11-10-2014, 01:08 PM | #5 | |
Rep 701
http://www.m3post.com/forums/showthread.php?t=1055546 The ancedotal evidence is all over the place. I am choosing to err on the side of caution. The car is plenty fast to me already. The potential for engine damage, the added weight and heat are not appealing to me. |
11-10-2014, 01:12 PM | #6 |
Rep 1,678
Drives: 2011 MCB E92 M3
Superchargers are NOT causing bearing failures. Stop spreading misinformation.
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
11-10-2014, 01:14 PM | #7 | |
Rep 701
He's stating in accelerates wear in an engine that is already at the limits bearing wise. And that makes sense. |
11-10-2014, 01:15 PM | #8 |
General
63062
Rep 24,605
10W60 for a reason.... I knew that !
And how can SC causing bearing failure as the most bearing failures had no SC ? THX for sharing .
11-10-2014, 01:22 PM | #9 |
Rep 1,678
As stated already, a supercharger puts extra strain on ANY and ALL engines, but is not specifically wearings bearings out 10x more than NA motors. A SC is not the cause for bearings to fail, we can blame BMW's engineers for their brilliant clearances.
11-10-2014, 01:48 PM | #10 | |
Rep 734
Why would SC increase failures? More heat, more force on the bearings which is more load on the bearings and more likely to decrease oil flow, more likely to experience preignition. Also, folks going through that expense and risk are very likely to use more power, more of the time than an "average" M3 owner. |
11-10-2014, 01:58 PM | #11 |
Bad Lieutenant
232
Rep 3,517
Dave,
Thanks for posting, I think I saw this "live" on the site; what he states makes sense. For all the rest of the bearing discussion(s), these are my thoughts:
11-10-2014, 03:48 PM | #12 | |
Rep 409
The problem with all these oil recommendations is that if your engine grenades and you go to BMW and try to get it fixed under warranty they have their ammunition...did you use our oil recommendation? NO, sorry then, you messed up the engine because you didn't follow our recommendations... |
11-10-2014, 04:34 PM | #14 | |
General
63062
Rep 24,605
Actualy it became a worldwide mistake....
11-10-2014, 04:36 PM | #15 | |
Rep 409
More power = more wear/stress on engine. Last edited by Sinful; 11-10-2014 at 04:48 PM.. |
11-10-2014, 04:47 PM | #16 | |
Rep 409
I mean if your doctor says your grandpa has a heart problem you don't recommend he follow you to do wind sprints ... |
11-10-2014, 05:29 PM | #17 |
is fast cars
391
Rep 2,137
11-10-2014, 05:32 PM | #18 |
Rep 5,506
He responded about 0w30 when you asked about 0w40? He mentions 5w30 in his response as well which is thinner than 0w40. I would agree with him that 0w30 is too thin.
Auto Detailing Enthusiast!
11-10-2014, 06:28 PM | #19 |
Rep 734
Unless you're beating on the engine cold, the "0" low end number is IRRELEVANT to the conversation of bearing failure. In fact, it likely REDUCES the chances, since cold lubrication is superior.
The reason you wouldn't run a 0W-30 is because 30 is not NEARLY enough for the temps an engine with these specs would generate. That 30 is going to be about 3 on track, when you're seeking about 10. The difference between 0W-30 and 0W-40 at cold start of the engine is the difference between water and H20. The exact same applies to 5W-30 vs. 0W-30 at full operating temp: IDENTICAL.
... a glorious V8 that screamed and hollered as the revs rose and then howled in an orgy of what sounded like BDSM ecstasy as it neared the red line.
Well, you can forget all that. The new car is fitted with a turbocharged straight six. Turbocharging? In an M car? That’s like putting gravy on an ice cream. - Jeremy Clarkson, discussing the S65 and then S55 M3 engines. |
11-10-2014, 06:36 PM | #20 |
Rep 6,860
Who is this "car tech" and what is this q&a in reference to? Not sure anything new was really said here. Everyone knows there may be risks with a supercharger and I don't think anyone is using 0w30.
11-10-2014, 09:53 PM | #22 | |
is fast cars
391
Rep 2,137
Daddy's Rocket Sled!
Clarkson: "It is... pretty much perfect... Why don't I have one of these cars?" Harris: "The saloon is definitely the M3 of choice." |
