03-18-2014, 12:11 PM | #1 |
Rep 390
Drives: '16 M3, Lotus Exige S260
Bent valve! Causes and long term...
My M3 apparently decided to eat a valve. After getting the engine malfunction nav display and a quite noticeable dropped cylinder or more while driving my local dealership just diagnosed a bent valve in cylinder 8.
Considering I was merely cruising at around 65 mph in 7th (DCT) on the highway when it happened, can anyone help me understand what could have caused this? Is there anything I should worry about with the dealer repairing this? Thanks, Scott PS - I've probably been nicer to my M3 than any other car, no performance mods at all, no racetrack time, daily driver duty. Just over 16,000 miles. Average 20.6mpg even! |
03-18-2014, 12:24 PM | #2 |
Stop the hate, get a V8
3850
Rep 8,625
Did they inspect the piston to see if it collided?
Past: 2011.5 M3 sedan ZCP |
03-18-2014, 12:32 PM | #3 |
Moderator
94
Rep 1,920
Very odd. The only time I have heard of M3's eating valves is from over-rev. I did it once in my E36 M3. :-)
the only thing I could even think of is oil starvation/oiling issue. Have you been diligent in your oil changes? My car is also low mileage (only 20K on it since new in 2008). You have to change the oil every 6 months or so. Being as the car sits a lot, you will get a lot more condensation (water) in the oil. If it isn't driven a lot (with oil temps over 212), you won't burnt off (vaporize) the water. That's all I can think of....let us know what you find out. Edit: I see your car is newer...I was thinking it was an "old one" like mine. Never mind the above. I have no idea wth would cause it...please let us know what you find out.
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket 2014 F30 328i -- Kids car 2008 E90 M3 -- Sold 2004 GT3 -- Sold 1997 M3/4 -- Sold 1995 M3 -- Sold |
03-18-2014, 12:38 PM | #4 |
Rep 1,463
So the dealer took apart the head? Was it the exhaust or intake valve? Did they check the timing? If that is off it could account for the bent valve. I would also advise checking the piston.
03-18-2014, 01:26 PM | #5 | |
Rep 2,000
If you did do a money shift, they'll know, so be prepared to open your checkbook wide. Bruce PS - Did a money shift (3-2 instead of the attempted 3-4) on an E36, and a new long block (installed) cost me $8800. Bummer. |
03-18-2014, 01:39 PM | #6 |
Rep 3,633
Most likely the valve spring failed which has happened a number of times on these cars. Yours just got worse luck and collided with the piston to bend the valve
Edit: I say most likely but due some searching and you'll see similar cases; I would bet this is the problem; Good luck! |
03-18-2014, 01:41 PM | #7 |
Rep 1,463
Possibly, but the dealer would have then diagnosed it as a broken valve spring with the bent valve being a result of that. Over-rev, timing issues are the likely culprits.
03-18-2014, 01:43 PM | #8 |
Rep 3,633
we're talking about BMW techs. It's probaly semantics in the way it was relayed to OP; either way Good luck OP
03-18-2014, 01:44 PM | #9 |
Rep 1,096
Drives: Melbourne Red e90 M3
there are a few reports on this forum of bent valves if you search. Theory is a bad batch of valve springs used on our engines.
03-18-2014, 02:57 PM | #11 |
Rep 4,381
03-18-2014, 05:04 PM | #12 |
Rep 1,017
average 20.6mpg ?! wow who gets such an average on an M3. I don't think you can brake-in the engine properly if that was your mpg average during break in too.
At least you're lucky it happened under warranty. Sounds like your car was bought in 2012. I have a 2013.9 (I consider it the 2014 model ) and don't have 4,000 miles on it yet. I make sure to take it on longer trips once in while so that all the fuel and water that condensate in the oil has time to fully evaporate. I've read that condensation will raise your oil level and if you were near overfilled could possibly this lead to such a failure ? |
03-18-2014, 05:44 PM | #13 |
Rep 1,381
How would you overrev a DCT without something else failing before hand to allow it? I thought the car will always override any commands to the gearbox that will lead to overreving provided everything is working the way it should
03-18-2014, 05:53 PM | #14 | |
3850
Rep 8,625
I just did 20.1mpg on my last tank. If you're cruising at about 70mph on the highway for most of the tank, it's definitely attainable.
03-18-2014, 09:05 PM | #15 | ||
Rep 390
I fired off an email to the dealer asking about piston contact -- but kind of assumed the answer was yes from their first call. Hopefully I was wrong. I'm waiting to hear back from them now. |
03-18-2014, 10:39 PM | #16 | |
Rep 157
At 33000 miles now. Nothing else has broken...yet. I'm more of a 15-16mpg'er Good luck with repairs. |
03-18-2014, 11:30 PM | #17 |
Rep 1,017
03-18-2014, 11:32 PM | #18 |
Rep 1,017
03-18-2014, 11:37 PM | #19 |
Rep 1,133
Drives: 2008 Jet Black M3 Coupe
My average mpg has gone from 20.1 pre benvo tune and crept up to over 23 mpg and i drive it harder all the time. i posted a pic on here somewhere.
03-19-2014, 03:25 AM | #20 | |
Rep 4,381
Like I said its unlikely. |
03-19-2014, 08:19 AM | #21 |
Rep 572
Broken spring lock or worn valve guide. If there was no piston contact and you didn't continue driving it you may be ok. Post up when you get a diagnosis from the dealer.
03-19-2014, 12:26 PM | #22 | |
3850
Rep 8,625
The amount of fuel in the oil is going to be extremely low. These are not direct injection motors. My most recent UOA showed the fuel content as being "under 0.5%", which is effectively 0. Other UOAs posted here show similarly low numbers. I would worry more about moisture in the oil, but even that will be burned off within a few minutes of the oil passing the 160 F mark.
