08-22-2011, 07:25 PM | #1 |
Putcha ang ganda...
281
Rep 5,441
What should i do. IDLE PROBLEM
Ok for the last 2 months my car has been acting up... For 2 months my idle had been intermitent fluctuating up to 1.5k but im not getting any error.... I had called the dealer and it has been in the dealer twice but they just cant get it to duplicate the issue.... This issue had happen 6 times in 2 months but my freakin engine light just so stubborn SOB...
What other suggestion do u have...
08-22-2011, 07:40 PM | #2 |
Putcha ang ganda...
281
Rep 5,441
Adding more info: its a 2008 with 45k... I know the MY08 has issue with the ICV... But the dealer just wont do anything cause of no fault showing....
08-22-2011, 09:05 PM | #4 |
Putcha ang ganda...
281
Rep 5,441
I have only use 2 gas station for the last 2 1/2 years which is Chevron but ill try to add the add on techron that bmw recommend.... Thanks ive always assume that it might be the idle valve going out soon but hope its something else....
08-22-2011, 09:17 PM | #5 |
Rep 85
I just had the same problem with MY09. The idle would drop from 1.2 to 500. I would get a reduced engine power malfunction then it would go away and come back. It took the dealer forever to figure it out, but eventually they changed the fuel injectors and everything is back to normal.
2015 F82 BSM
2009 E92 M3 AW/FR |
08-23-2011, 07:16 AM | #6 | |
1122
Rep 7,690
Techron will clean your injectors and lines but also you have to know that if your injectors are not flowing as they should,an error msg will pop on ur idrive.Try the techron and lets hope that it will be fixed. |
08-23-2011, 08:59 AM | #7 | ||
Putcha ang ganda...
281
Rep 5,441
if anyone had this issue please post. since it doesnt seem like its the ICV problem.
08-23-2011, 11:26 AM | #8 |
Rep 65
On cold Starts in the morning it happens to my car. The rpms go to 1500, then seems like the car is choking and goes down to 600 then back up to 1100 and settles down with a bit of stuttering then its all good.
What's weird is that it only does it in the morning the first start of the day.I gass up with 94 octane (petro Canada). If it was the ICV wouldn't the idle always be shaky? |
08-25-2011, 02:54 PM | #10 |
Rep 15,818
mobile isn't tier 1..stay away..
08-25-2011, 07:32 PM | #11 |
1122
Rep 7,690
08-26-2011, 10:28 AM | #12 | |
Rep 15,818
91 only at Mobile SOME gas stations (usually a 76 or a no-name) have 100 Never seen 93 anywhere here I just remember reading reports that they're not tier 1 over here thus not up to par.
08-26-2011, 02:12 PM | #13 |
1122
Rep 7,690
To be honest, I only use Shell and Mobil.tried others in the past and had to deal with water mixed with the fuel so i use those two now unless im in the middle of no where and i need to gas up and got no choice.
08-26-2011, 07:11 PM | #14 |
Rep 5,012
Both folks who reported idle problems have their ICVs on the way out. At least for what I've read in the past 2 years. But until you have faults, don't waste your time at a dealer. The good news is when it happens, you can usually clear the 'limp mode' a few times by cycling the ignition. But at that time, you better take the car in soon. If you search, there're different symptoms, and sometimes it has been something else, but idle going high is an unmistakable ICV problem.
I also have experienced a couple of almost stalling episodes before shutting engine off (when I get to my destination), but not revs going higher than idle. It could also be my ICV, but I'd probably say in my case it could be the gas. Both instances were on a trip, where I couldn't fill up at a Chevron station, which I always do. Chevron gas will NOT be the issue, unless it was from a tiny gas station, and gas was bad. I always fill from large stations. Good luck, and keep us posted. |
12-04-2011, 08:24 PM | #15 |
CMPULSV
20
Rep 359
Any follow up on this? I am experienced the eng idle flux
2009 Alpine White DCT E92 M3 - Tint, Hood M Stripes, Eibach Springs,
Gloss Black Rims, Vorsteiner Lip, BMW Performance Trunk Spoiler Fabspeed x-pipe & Megan Race Exhaust 2006 Imola Red 6-speed E46 M3 - Retired |
