06-01-2013, 12:24 PM | #1 |
Rep 229
What software am I running???
just picked up my 2011 M3 from the dealer and I was told Im running I level E89X-10-09-511? I am trying to make sure that it has been updated to the newest 240E update!?
06-01-2013, 01:01 PM | #3 |
Rep 219
stolen from another thread:
http://www.m3post.com/forums/showthread.php?t=797020 Legacy: Progman - 28.0 - E89X-07-12-515 Progman - 28.0.1 - E89X-07-12-515 Progman - 28.0.2 - E89X-07-12-515 Progman - 29.0 - E89X-08-03-510 Progman - 29.01.2001 - E89X-08-03-520 Progman - 29. Feb - E89X-08-03-520 60E: Progman - 30.0 - E89X-08-03-530 Progman - 30.0.1 - E89X-08-03-540 Progman - 30.0.2 - E89X-08-03-540 Progman - 31.0 - E89X-08-09-515 Progman - 31.1 - E89X-08-09-520 ISTA/P - 2.31.0 - E89X-08-09-515 ISTA/P - 2.31.1 - E89X-08-09-520 ISTA/P - 2.31.1.1 - E89X-08-09-520 ISTA/P - 2.31.1.2 - E89X-08-09-520 ISTA/P - 2.31.2 - E89X-08-09-530 80E: ISTA/P - 2.32.0 - E89X-08-09-530 ISTA/P - 2.32.1 - E89X-08-09-530 ISTA/P - 2.32.2 - E89X-08-09-530 ISTA/P - 2.33.0 - E89X-09-03-510 ISTA/P - 2.33.1 - E89X-09-03-520 ISTA/P - 2.33.2 - E89X-09-03-520 ISTA/P - 2.33.3 - E89X-09-03-520 100E: ISTA/P - 2.34.0 - E89X-09-06-510 ISTA/P - 2.34.1 - E89X-09-06-510 ISTA/P - 2.34.2 - E89X-09-06-510 ISTA/P - 2.35.0 - E89X-09-09-515 ISTA/P - 2.35.1 - E89X-09-09-515 ISTA/P - 2.35.1.1 - E89X-09-09-515 ISTA/P - 2.35.2 - E89X-09-09-516 ISTA/P - 2.35.3 - E89X-09-09-516 ISTA/P - 2.35.4 - E89X-09-09-516 140E: ISTA/P - 2.36.0 - E89X-09-12-510 ISTA/P - 2.36.0.1 - E89X-09-12-510 ISTA/P - 2.36.1 - E89X-09-12-512 ISTA/P - 2.36.1.1 - E89X-09-12-512 ISTA/P - 2.37.0 - E89X-10-03-501 ISTA/P - 2.37.1 - E89X-10-03-502 ISTA/P - 2.37.2 - E89X-10-03-504 170E: ISTA/P - 2.38.0 - E89X-10-06-500 ISTA/P - 2.38.1 - E89X-10-06-501 ISTA/P - 2.38.2 - E89X-10-06-502 ISTA/P - 2.39.0 - E89X-10-09-501 ISTA/P - 2.39.1 - E89X-10-09-501 ISTA/P - 2.39.2 - E89X-10-09-511 ISTA/P - 2.39.3 - E89X-10-09-511 ISTA/P - 2.39.4 - E89X-10-09-511 190E: ISTA/P - 2.40.0 - E89X-10-12-501 ISTA/P - 2.40.1 - E89X-10-12-501 ISTA/P - 2.40.2 - E89X-10-12-503 ISTA/P - 2.40.3 - E89X-10-12-503 200E: ISTA/P - 2.41.0 - E89X-11-03-501 ISTA/P - 2.41.1 - E89X-11-03-502 ISTA/P - 2.41.2 - E89X-11-03-502 ISTA/P - 2.41.3 - E89X-11-03-510 ISTA/P - 2.41.4 - E89X-11-03-511 220E: ISTA/P - 2.42.0 - E89X-11-03-511 ISTA/P - 2.42.1 - E89X-11-03-511 ISTA/P - 2.42.2 - E89X-11-03-511 ISTA/P - 2.43.0 - E89X-11-09-501 ISTA/P - 2.43.1 - E89X-11-09-503 ISTA/P - 2.43.2 - E89X-11-09-503 ISTA/P - 2.44.0 - E89X-11-09-505 231E: ISTA/P - 2.45.0 - E89X-11-09-506 ISTA/P - 2.45.1 - E89X-11-09-506 ISTA/P - 2.45.2 - E89X-11-09-506 ISTA/P - 2.46.0 - E89X-12-03-500 ISTA/P - 2.46.1 - E89X-12-03-502 ISTA/P - 2.46.2 - E89X-12-03-502 ISTA/P - 2.46.3 - E89X-12-03-502 ISTA/P - 2.46.4 - E89X-12-03-502 240E: ISTA/P - 2.47.0 - E89X-12-07-502 ISTA/P - 2.47.1 - E89X-12-07-503 ISTA/P - 2.47.2 - E89X-12-07-504 ISTA/P - 2.47.3 - E89X-12-07-504 ISTA/P - 2.47.4 - E89X-12-07-506 ISTA/P - 2.47.5 - E89X-12-07-507 ISTA/P - 2.47.6 - E89X-12-07-507 ISTA/P - 2.47.7 - E89X-12-11-507 ISTA/P - 2.48.0 - E89X-12-11-507 |
06-01-2013, 01:34 PM | #5 |
Rep 219
not as far as im aware its either dealer and asking them for a mini-service print out from your key (they do this at the service desk) or reading the I-LEVEL from a coding cable via NCSEXPERT etc
06-01-2013, 01:36 PM | #6 |
Rep 219
there is an I-LEVEL that shows up as E89x-12-07-508 that may seem like 240E and it might very well be if all modules in your car have been updated, but its also the level that gets set when you have the BMW security update and you might not have 240E. checking the version of each module again through the coding cable or asking BMW to supply this will tell you if you have the full update or just the security update.
06-01-2013, 02:03 PM | #7 |
Rep 229
Well I just asked my SA to have the tech list the software It it possible to drop by and find out from a key read or should I just ask them to verify it next time I take it in? If its not the most current or as in both modules then I guess I can just say the DCT is acting up in 2nd or jerky etc and have them or request for the latest software update?
06-01-2013, 02:20 PM | #8 |
Rep 219
if they said they would do it as part of the update id ask them to verify it via the mini-service report, and this will show:
Plant Integration Current Integration Target Integration With Plant Integration being the version it left the factory, Current Intergration is the version it currently has on (which should match your E89X-10-09-511, you might also find this is teh same as Plant Integration) and Target or Update Available will either be a higher level or say YES/NO. If NO then your on the highest (which is not true in your case) so yours will say YES. If you didnt ask for it as part of a deal, then just mention you use D a bit and when you slow down and come to a stop (traffic etc) then press the pedal again before coming to a complete stop, say the gearbox is irratic to change and like a kangaroo before moving away. But that might only get you the DCT update, you really want all modules updated (they basically plug it in to the computer and let it do its updates). in the UK we pay about £120 for this (guestimate at $180). But see if you can get it for free. |
06-01-2013, 02:43 PM | #9 |
Rep 324
So what is the benefit of updating the software? Is there a difference in power output or torque curve? Or is it just a case of throttle sensitivity and smoother idle? I have the manual so obviously DCT shift problems are not my concern.
06-01-2013, 03:02 PM | #10 |
Rep 219
the updates are usually to fix specific issues, but if your on a really old version then moving to 240E will bring benefits on its own. For the other modules e.g. bluetooth/CIC (satnav) etc then it brings new things like ability to pair to newer phones or fixes to album art/map updates etc. Engine wise its smoother operation.
Like everything any issue that is found is applied to the latest version, its also the version with all known issues fixed so just because you havent foudn an issue doesnt mean you wont have one in the future if your on an early version (of course you might not have an issue as well). I just think of it as Windows updates, I might not use some of the things it updates, but at the same time I dont want something on my car that might break or could break incase it has a knock on effect. |
06-01-2013, 03:42 PM | #11 | |
No military grade
58
Rep 619
Album arts are only supported on the NBT (at least from a Gracenote DB), not on the CIC, but NBT is not available for the M3 E9x and never will be - except for custom retrofits. Album covers in ID3v2 tags of MP3 tracks cannot be "fixed". Map updates are not included in a software update but have to be bought separately (dealers cannot give you that for free as they have to order a map FSC). With a software update, you could only benefit from smoother DCT shifts, better engine software and the security update for theft protection.
06-01-2013, 04:09 PM | #13 |
General
63411
Rep 24,686
I think you are wrong....check this out v v v
http://www.m3post.com/forums/showthr...=847261&page=4 |
06-01-2013, 04:16 PM | #14 |
No military grade
58
Rep 619
There may be a little performance benefit if your initial software is very old. Many people say that the 231E was the biggest increase performance-wise, but I cannot tell since I had that one from the start (build date 10/2011).
Initial criticism about many cars not reaching their advertised power was caused by the early ECU software weakness. But the 414hp claim was made in the first place because Audi claimed the same at that time. The development target was 400hp, which was what could be done by both the N54 and the S65 (which were the two alternatives BMW decided between for the M3). So, the 300hp rating for the N54 may be somewhat on the low side whereas the 414hp for the S65 may be somewhat too high. The DCT improvements between 2011 and now are VERY noticeable, however.
06-01-2013, 05:52 PM | #16 | |
Rep 7,542
Edit, you're probably on 170E which isn't super old.
06-01-2013, 06:32 PM | #17 |
Rep 324
06-01-2013, 07:07 PM | #18 |
Rep 8,496
I just upgraded from 80E to 240E. I noticed major improvement in low rpm throttle smoothness. I also noticed a 2 mpg improvement bump in highway driving. Imo, this update is a must
06-01-2013, 08:24 PM | #19 |
Rep 324
How much did it cost you? And is it just one version or do they have different versions depending on the equimpent of the car like nav/edc/satellite radio,etc?
06-02-2013, 05:52 AM | #20 | |
No military grade
58
Rep 619
240E is just the ECU software. BMW has the so-called integration levels (like E89X-12-11-507) for each car series (E89X) that are inherent with the ISTA/P releases (like 2.48.0). These comprise all possible softwares for any electonic unit that can be employed in that car series. BMW dealers can only update to the most-current ISTA/P release at any given time, so the update will always bring any unit on the car to the most current level.
06-02-2013, 06:23 AM | #21 |
Rep 219
but they can also target specific modules rather than "full" update e.g the security update to CAS (not sure if its just a UK thing) will show E89x-12-07-508 but only CAS will have been updated and rest of the modules including ECU will be as they were. so make sure you get a FULL update and ask for a print out to confirm
06-02-2013, 06:34 AM | #22 |
No military grade
58
Rep 619
No, they (i.e. BMW dealers) will not do an update for just a specific unit.
While that is possible, BMW dealers are not allowed to do it, because only the software versions contained in an integration level are tested to work together. Normally, they use only BMW-supplied software like ISTA/P which automatically builds an update plan to program all units that require an update to reach the target integration level. Notwithstanding, depending on the old integration level this can mean that only a few (or even only one) unit(s) like CAS will get an update.
