BMW Garage | BMW Meets | Register | Search | Today's Posts | Mark Forums Read |
BMW 3-Series (E90 E92) Forum
FS for 335i differential AT 07/2007 build large bolted
11-11-2012, 08:01 PM | #1 |
Rep 1,529
its a 07/07 build AT in excellent condition large bolted 3.46 ratios if you have a manual , this is a easy way to pick up some speed and fun with gearing http://www.vacmotorsports.com/blog/3...no-lsd-really/ http://www.vacmotorsports.com/blog/w.../diffchart.jpg 250 shipped or 225 picked up in miami. |
11-11-2012, 08:38 PM | #3 |
Rep 1,843
how many miles on it? Also, any idea whether this would throw off the speedo on a 6MT car or does it now pick up off the wheel speed sensors not the tranny? Thanks!
11-11-2012, 10:25 PM | #5 |
Rep 1,529
just to clear things up to answer the ridiculous amount of questions i am getting:
to see if this is a plug and play, go to your car, open the door and read the manufacturing date. then match to http://www.vacmotorsports.com/blog/w.../diffchart.jpg if yours is bolted, then its plug and play |
11-11-2012, 10:26 PM | #6 |
Rep 1,529
if its welded, your SOL, and its a PITA where you have to send it to a shop to open your weld and then its plug and play. unless YOU own the shop then its cheaper and easier.
11-12-2012, 11:19 AM | #8 |
Rep 1,843
didn't mean to ask dumb questions, I'm interested but financially embarrassed right now I knew about the bolted vs. welded thing just didn't know whether changing the ratio had any other implications or not. If you still have this when I have money again I may pick it up with an eye toward a future LSD swap. In any case GLWS.
11-12-2012, 08:13 PM | #11 |
Rep 967
Large pumkin means it will reaquire a shorter driveshaft for my 10/07 build xi car, correct?
| PROcede Rev3 | Vishnu Meth | DCI | BMW Perf. Exhaust | AR Coated/Catless | CP-E FMIC | Quaife | |
11-12-2012, 08:31 PM | #12 |
Rep 1,843
if you put this in an xi you better change the front diff to a 3.46 too!
I don't know about the driveshaft but I would suspect that you may need one and also axle shafts as well, if you have a "small" diff. |
11-24-2012, 10:00 AM | #16 |
Rep 783
This cant work by just putting it in a 3.08 pumpkin. The ring and pinion from your 3.46 are also required. Do you have those available as well?
'07 335i E90 - PTF ProTUNED by Dzenno - COBB FMIC - AFE DCI - AA DPs - HFS4 Meth
'09 M3 - Stock |
Tags |
differential |
