      09-28-2020, 08:26 AM   #1
Toolmantim
Drives: BMW e93
Help with Tensioner Bolt Torque spec needed
SO I need help clarifying correct torque for e9x M3 belt tensioner main bolts. Im in the middle of replacing belts, Idler Pulley & both tensioners on my 2008 M3, but cant seem to find any listing of a torque specified for the main tensioner bolt (not the one attaching the pulley to tensioner arm, the one attaching the tensioner arm/device to the engine.
I found the Idler pulley in the manual I purchased online and other threads. but nothing else. Found a few conflicting BMW Torque spec docs out there. the 2 x M8 10.9 bolts attaching the Hydraulic tensioner strut to the engine or the tensioner arm seem to be 34Nm (25lb ft)based on general torque spec from newtis: https://www.newtis.info/tisv2/a/en/e...ations/5gDQK89
The main bolts on the tensioner arm device are M8 8.8 and the general torque is listed as 19Nm. but this seems a lot less that I would expect. when removing the tensioners, the main bolts seemed to have greater resistance than the 2 small bolts attaching the tension strut.
Thanks in advance.
      11-30-2020, 10:00 AM   #2
agenator
Drives: 2008 BMW M3
did u ever find the correct torque specs? I am tackling this job over XMAS break. Thanks!
Tags
help a noob, s65, tensioner, torque
