08-19-2014, 02:22 PM | #1 |
just another M3
514
Rep 1,152
Rod Bearings are done.
Okay here's my issue. After reading several treads and starting to feel my engine getting rough. I started to really look into the rod bearing issues. So I decided to get my rod bearings done over at Alekshop. Got to say the guys there are really helpful and very knowledgeable. I opt using for WPC treated bearings and the rest all OEM. My engine was already making a ticking sound. Also my copper count on my Blackstone oil readout was high. Here's a look at the bearings. My engine feels smoother throughout the high RPM range and a ticking sound is gone. It also runs 20 cooler. I got to say this is a true issue for the S65. I have 80K miles. I do daily drive my car and track it 5 to 6 times a year. I don't think this issue is related to track or not, just daily driving affects this engine. Feel free to ask any questions and I hope this helps out the form.
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
08-19-2014, 02:31 PM | #3 |
Rep 12,316
Yikes. What copper PPM did you see?
I just passed 80k myself, but got pretty good reading thankfully.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
08-19-2014, 02:33 PM | #4 |
Rep 1,678
Drives: 2011 MCB E92 M3
Was the prior ticking noise very rhythmic or kind of random sounding and did it increase when slowly adding throttle?
What oil did you run prior and are you still running the same after getting the bearings swapped?
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
08-19-2014, 02:35 PM | #5 |
General
64404
Rep 24,903
For a car with 80K on it the bearings look bad,but not too bad ! Actualy saw worse with less on it !
But need to say if you heard the ticking sound and you are planning to keep the car ,the WPC's are the right choise ! Hope that your car is ready now for another 80K Also whats makes me think more and more....still need to see the first Euro/bearing failure ! Thanks for sharing
08-19-2014, 02:42 PM | #6 |
Rep 1,620
2023 G80 M3 2020 F87 M2C 2011 E82 BMW 1M Series Coupe Check me out at Point.Shift.Drive (YouTube) |
08-19-2014, 02:42 PM | #7 |
Rep 3,152
Ouch. Glad your car is ok and back on the road.
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
08-19-2014, 02:51 PM | #8 |
Master Baiter
4173
Rep 631
Drives: 18 M2
I have a couple of questions.
Did they just remove and replace, or did they do any measuring on the crank rod journals? Is there only one size of bearing that is available? Do you know any torque specs on the rods? Thanks. |
08-19-2014, 03:03 PM | #10 |
Emperor
1614
Rep 2,753
Looks like you caught those just in time!
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport |
08-19-2014, 03:05 PM | #11 | |
just another M3
514
Rep 1,152
08-19-2014, 03:15 PM | #13 | |
just another M3
514
Rep 1,152
I always use TWS 10w60. But the last 10k I used motul v300 10w40 with a bottle of redline zinc additive.
08-19-2014, 03:19 PM | #14 | |
just another M3
514
Rep 1,152
08-19-2014, 03:21 PM | #15 | |
just another M3
514
Rep 1,152
08-19-2014, 03:22 PM | #16 | |
just another M3
514
Rep 1,152
08-19-2014, 03:23 PM | #17 | |
just another M3
514
Rep 1,152
08-19-2014, 03:26 PM | #18 |
just another M3
514
Rep 1,152
This is after 45 miles of drive. Before it would about the same but on the other side of the mark
08-19-2014, 03:28 PM | #19 |
just another M3
514
Rep 1,152
Pic
08-19-2014, 03:32 PM | #20 |
Rep 1,678
That is a huge change in oil temperature. I wonder why this would affect it so much?
08-19-2014, 03:34 PM | #21 |
Rep 6,771
Drives: 2016 BMW i8
Bad rod bearings cause excess heat/oil temps.
08-19-2014, 03:53 PM | #22 |
just another M3
514
Rep 1,152
I also moved to a 5w40 Pennzoil euro ultra.
