09-28-2016, 09:47 PM | #1 |
Rep 99
Ess 625 low boost issue
Recently i had purchased a 2011 m3 with a ess 625 kit all ready on the car which was supposed to have been professionally installed. I had the car dynoed
The numbers were much lower then expected. 450hp/305trq. So I started looking into the issue. The car will not make more then 5.6 psi in 4th gear which was the most I could get out of it. updating: as i resolved my issues with solutions. Improper routing of the belt.... still not sure how you do this and I am a bit mad at myself for not noticing it sooner. In hind sight I actually dont think the belt was slipping which is hard to believe considering everything. Belt slip- More to just rule it out. Replaced belt with a 6pk2115 belt, new tensioner, replaced idlers. Note a '83-'91 TOYOTA CAMRY uses the same idler per the part#... if you are like me and in a hurry this may be helpful also the koyo part#PU355816RR9D diverter valve leaking- replaced the oring and blader inside of the valve. Which can be had from superchargersonline.com or vortech. Mine was fold it over and had a hole so it was sealing some times and once fully expanded was leaking. I actually ended up replacing the valve itself with the new style max flow unit. Which is a much nicer unit imo. boost leaks This ended up being the root cause. The manifold was not properly seated on the original install and wrecked the boots on the throttle bodies. Last edited by craio11; 10-24-2016 at 09:44 AM.. Reason: updated |
09-29-2016, 08:51 AM | #2 |
Rep 1,678
Drives: 2011 MCB E92 M3
Check every velocity stack for a leak. There's got to be one somewhere.
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
09-29-2016, 10:16 AM | #3 |
Rep 99
I have inspected them fairly closely I did not see any issues, I am going to look a bit harder tonight and use a real smoke machine. The improvement in psi from the belt and tensioner makes me feel better that I do not have more serious issue such as a bad/damaged charger.
It just boggling my mind why the boost is diminishing per gear. My thoughts are along the same lines as you, there has to be a leak. Possibly because of the longer time in the higher gears its more prevalent. Would a bad diverter valve/spring cause this issue? |
09-29-2016, 10:20 AM | #4 |
Rep 1,678
The diverter valve has been known to fail, resulting in lower psi, so it's not out of the equation.
09-29-2016, 11:13 AM | #5 | |
PAZUZU
545
Rep 2,058
Drives: '15 M4
MilehighM3915.00 |
09-29-2016, 11:14 AM | #6 | |
Rep 1,678
09-29-2016, 11:21 AM | #7 | |
PAZUZU
545
Rep 2,058
Drives: '15 M4
i'm still guessing belt slip. i do have more boost under 1st and 2nd but the range of boost should not vary like the OPs. ps an indicator of the valve not connected right is a loud fluttering sound from the diverter valve. i heard it on a video a friend took of me when I passed him under full load. it sounded like a turbo blow off valve. the next day I removed my manifold and corrected the vacuum line error.
09-29-2016, 04:22 PM | #8 |
Rep 99
I do have my boost gauge T ed into the line that goes to the diverter valve. I believe it to be correct as I spoke to the original owner and he said the car use to make 7 psi. If it is belt slip im not sure what else i could do to correct this. The belt is a 6pk2115 which is shorter then the original as i was hoping this would fix my issue. Unless the new belt is garbage also. I dont hear any flutter but the exhaust is loud enough where I dont know if i would. No one has ever mentioned hearing a flutter sound
09-30-2016, 12:08 AM | #9 | |
PAZUZU
545
Rep 2,058
Drives: '15 M4
2009 M3 DCT ESS625+ SOLD 2015 M4 BSM/Silverstone F4LCON @texasMclub IG @jagemoets Last edited by Patrón; 09-30-2016 at 12:15 AM.. |
09-30-2016, 08:36 AM | #10 |
Rep 99
Im at roughly 1200' for elevation, running 93 octane, and the ambiment has been in the mid 50's. I have a remote 5 gallon tank in the trunk I double checked that last night pump is pumping strong so i dont think iats are my issue.
For my vacuum at idle i want to say it was 13-14 around 800 rpms which seems low. but this is also off the top of my head so this might be something I need to double check. the car runs fine and idles fine so i never bothered to look but this would single I have a leak some where. My main problem now is that i seem to have lots of potential small issues possibly going on. Last edited by craio11; 09-30-2016 at 08:46 AM.. |
09-30-2016, 09:56 AM | #11 | |
PAZUZU
545
Rep 2,058
Drives: '15 M4
09-30-2016, 10:18 AM | #12 |
Rep 99
Im going to try and take it back to the dyno, the power could be there and i dont realize. but you would think the butt dyno could feel 80-100 hp.
Im to the point where im just about to take everything off and re do the install. |
09-30-2016, 01:06 PM | #13 | |
PAZUZU
545
Rep 2,058
Drives: '15 M4
have you captured a video of the boost in 1st-3rd? how are you recording the boost readings?
09-30-2016, 02:23 PM | #14 |
Rep 99
hopefully it doesnt come to that but thanks for the advice. as for a video ill see if i can figure out a safe way to do that. Im just using the recall function on my p3 gauge to read peak boost.
Right now im leaning towards like you mentioned this current belt is garbage or the diverter valve spring is not able to hold boost for the longer period of time. |
10-01-2016, 12:52 PM | #15 |
Rep 99
4th gear pull
3rd gear pull. I was messing with the bypass valve tension screw. I don't seem to feel any resistance screwing it in. Also after messing with it my boost has seemed to gone back down |
10-04-2016, 09:18 AM | #16 |
Rep 99
well i was able to locate the problem. The blader in the bypass valve was rolled up on itself and had a pin hole in it. So when it would close it was rolling over the pin hole and sealing it at idle. So it was passing a smoke test and was able to hold vacuum.
10-06-2016, 08:20 PM | #17 |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
459
Rep 2,001
Drives: 2011 E92 M3 DCT/ESS 625 kit
Seems like I also got some low numbers 511/335tq I also have a 625 kit at around 7.5 pounds. I had the car reflashed before dyno was done so not sure why I didn't see higher numbers. What's the average numbers on a 625 kit??
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
10-06-2016, 09:28 PM | #18 |
Rep 1,385
depending on exhuast setup i've been seeing 520-540whp for a 625kit on pump gas
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
10-07-2016, 04:22 AM | #19 | |
459
Rep 2,001
10-07-2016, 11:16 AM | #20 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
Do you know what other Ms are putting out on the same dyno? Either supercharged or n/a? Do you know what the temps were during the dyno? The temps and intake temps can kill a lot of horsepower. As well as fuel octane and spark plugs.
10-07-2016, 11:19 AM | #21 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
Did fixing that rubber piece help your boost/power?
10-07-2016, 01:36 PM | #22 | |
459
Rep 2,001
