11-17-2017, 06:09 PM | #1 |
Rep 80
bucket seats
trying to understand a few things here, but here is my layout.
2013 M3, e92, all packages (EHP included). the questions i have are: 1. since i am about to hit GO on getting the sportster CS, heated, for the car, does EHP (enhanced premium sound) come into play with any of this? any under seat speaker/sub/etc or is there no relation? (just curious) 2. getting MS sliders - is there anything else i need? I still use stock seatbelts right? no need for a new occupancy sensor or anything correct? just code it out? if so, do i need to code for both or just passanger side? 3. are there other hardware req that i should look for or get to improve QoL now vs later? 4. if i go coding route, anyone have req? i live in bay area but if i go to LA i could visit a shop there too. can Carly do the same? |
11-17-2017, 08:42 PM | #2 | |
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
Stock belts should work fine. These are the same profile as a Bmw performance seat. You will need to code the occupancy sensor AND the airbag delete. Spirited CS delete the airbag in the side of the seat. You will need floor mounts as well as side mounts. If you also want to run a belt for the track, you will need additional hardware obviously. If your in the Bay Area, Alekshop, edge, SD auto tech and Trackspec are all places to consider to do the install |
