12-27-2015, 03:21 AM | #1 |
Rep 363
Suspension Upgrade..What else to do?
2011 e92 DCT
Just ordered my Ohlins R/T+Vorshlag camber plates What else can i do to improve the handling of my car, as i will be doing the coil overs and camber plates might as well throw in what i can, any suggestions? Also i have the Comp package wheels with 255/275 Yokohama Ado8R, Fresh! I am hoping to get the best handling from my car, I'm hoping to go to some track events and spirited driving as you call it around the mountains, PLEASE don't start hating on what i already bought, as i like Ohlins and got a GREAT deal and am excited to have it on, NOW if anyone can suggest anything else that would be greatly appreciated! Thank you Also i may be considering going to Apex ec-7 18' 9.5-10.5 with some Toyo R888.. |
12-27-2015, 05:02 AM | #2 |
Rep 2,527
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
I think when I upgrade my suspension I will do solid subframe bushings as well. From what I've read, it seems to help quite a big deal.
I also upgraded my front sway bar with the Dinan sway bar, and that seems to help a lot from what people say. I've heard bad things about the RD sway bar snapping from my shop, so I went with Dinan instead.
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
12-27-2015, 05:31 PM | #3 |
Rep 8,076
Drives: 11 E90 M3 Individual
Camber plates is really all the car needs. Just make sure the rest of the bushings are in good shape.
2018 F30 320iX Melbourne Red
12-27-2015, 07:47 PM | #4 |
Rep 12,726
i would respectfully disagree. i have been to a few track events with friends. one of the guys i go with is on coilovers, but oem brakes [race pads], and i'm on ap racing brakes with oem suspension. it is very easy to see the strengths of each car on the track when following each other.
he pulls away in the corners because of better cornering ability. i catch up to him approaching the corners because my braking zone is deeper. its a cycle of him pulling away in the corners and me being up his ass heading into a corner. coilovers make a big difference. op, look into the essex parts ap racing kit for our cars. they have two front kits now, and one rear kit. i have the "lesser" of the two kits just in the front of my car and the difference is huge.
12-27-2015, 09:22 PM | #5 | |
Rep 8,076
There's two ways "beat" your friend. Either spend money or further develop your skills. I'll say this...I've ran times in my E90 M3 with OEM non-EDC dampers and A Dinan Stage 3 suspension comparable to people in E9X's with coilovers and bolt on power adders. I'm off the brakes earlier, I turn in sooner, I get on the throttle sooner. With the E9X M3...it all comes down to how well you can drive with the throttle.
12-28-2015, 06:37 AM | #6 |
Rep 12,726
there are a lot of variables and dynamics coming into play, i was just giving an example of how different things magnify certain characteristics of this car.
i'm still new to tracking, but the front bbk drastically reduced how long i'm on the brakes before i let off and turn in.
12-29-2015, 01:13 PM | #7 | |
Rep 6,218
12-29-2015, 04:08 PM | #8 | |
Rep 12,726
12-29-2015, 06:54 PM | #9 |
Rep 2,400
Easiest ways to save lbs and improve handling are wheels (4 lbs per wheel vs ZCP), they should be 18", tires (Michelin Pilot Sport Cup 2s save 4-5 lbs per tire vs ADO8R), and Essex/AP racing BBK (between 4 and 6 lbs per corner depending on what kit you get). Basically you can save between 12-15 lbs per CORNER...this type of unsprung and mostly rotating mass reduction you will definitely feel..will feel like your car lost 200 lbs. Unsprung and rotating mass reduction can have 2x-5x the handling benefit of sprung mass reduction. Not to mention the tires will run cooler (will be less sticky after multiple laps) the suspension will ride better, you'll improve the responsiveness of the wheels/tires in surface/direction changes, and the brakes won't work as hard.
For benefit of others reading this thread, suspension weight can also be a consideration. The EDC shocks/springs are actually very light and lighter than most aftermarket suspension setups (using steel vs aluminum shocks). I have the TC Kline D/A coilover suspension, with the light alloy VVS springs, and per corner only weights 1-2 lbs less vs EDC. |
12-29-2015, 07:53 PM | #10 | |
Rep 12,726
also got rid of 21lbs of weight with the essex ap kit up front. i got rid of 31lbs (total) of unsprung/rotating weight up front with the essex kit when running my arc8's. thats pretty significant!
